Help with squeal on clutch engage needed
Old Jan 11, 2007 | 02:05 PM
xtal's Avatar
Default Help with squeal on clutch engage needed
I've had a very annoying problem the past few months, and tracking it down is a bitch. I've been through almost all common problems, so perhaps someone else has had this problem or I am missing something very obvious.
The noise in question happens when disengaging (releasing) the clutch in a forward gear. Worse on a hill, rolling back. Start to release the pedal, as the car starts rolling, I get a horrible squeal. The noiseis gone once the pedal is fully up. If I keep slipping the clutch, it will eventually go away with speed.
The squeal will NOT happen under any circumstances if I use reverse gear. Can reverse up the steepest hill I can find with no noise.
There are no other clutch symptoms to speak of. Nice fluid engagement, stalls car easily @ idle, etc.
I do not believe it is a brake seizing problem; rolling to a stop without using the brakes will not eliminate the noise on startup.
I've replaced and tensioned the power steering and alternator/AC belts. Both belts are snug, but not excessively so.
The only thing I can think of is the clutch is in need of replacement at this point.
Any ideas?
Old Jan 11, 2007 | 02:37 PM
thegeorge613's Avatar
Default Re: Help with squeal on clutch engage needed (xtal)
I'm thinking it's your thowout bearing or pilot bearing. I had the same problem, except mine is backwards (noise stops when clutch isn't depressed) and is less severe.
Maybe other experts can chime in also.
Old Jan 11, 2007 | 07:09 PM
red92s's Avatar
Default Re: Help with squeal on clutch engage needed (thegeorge613)
Throw out bearing
Old Jan 11, 2007 | 07:16 PM
94Vtecluder's Avatar
Default Re: Help with squeal on clutch engage needed (red92s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92s &raquo;</TD></TR><TR><TD CLASS="quote">Throw out bearing</TD></TR></TABLE>
Old Jan 11, 2007 | 07:34 PM
roller3804's Avatar
mines going to im gonna hold out till I can afford a new clutch to. Cause all that work just for a throwout bearing would suck.
def TO bearing though
Old Jan 11, 2007 | 07:40 PM
maverik's Avatar
Default Re: (roller3804)
mine was doing the same exact thing, and it was the throwout bearing. just got my car back today
Old Jan 11, 2007 | 08:12 PM
xtal's Avatar
Default Re: (maverik)
Crap.
I guess there wasn't much left but the clutch. It's been doing it for over 8 months, so I'm not imagining it's too severe. I asked Honda and they told me I had a sized caliper, good thing I'm not paying them $80/hr to track it down.
Hopefully it'll hold out until the spring, then I can do a clutch and flywheel upgrade.
Thanks for the replies. I'll do a writeup on how to do the clutch if one doesn't exist, I guess.
Old Jan 11, 2007 | 10:39 PM
bad-monkey's Avatar
probably the TOB, or maybe something on the clutch disk that's sticking out and rubbing against the flywheel ever so slightly.
if you ever feel like it's impossible to get the car in gear with the clutch disengaged, it's because the bearing's gone kaput. not a huge deal if you have AAA or can drive clutchless
Old Jan 12, 2007 | 09:26 AM
xtal's Avatar
Default Re: (bad-monkey)
Well, I don't use the clutch on my race car, but the lude isn't Hewland equipped just yet.
94rster
Aug 3, 2010 05:59 PM
headrec*
Transmission & Drivetrain
Aug 29, 2008 08:49 PM
InteGSR01
Honda S2000
Oct 10, 2007 11:20 PM
VTECRaZeR
May 30, 2003 11:10 PM
