shifter bolt gets loose !
Old Jan 10, 2007 | 09:05 PM
Extreez's Avatar
Default shifter bolt gets loose !
Hey guys, i have a 93 integra and i noticed that the bolt that connects the shifter below the car gets loose, cuz i get the bolt tight, stops rattling from time the rattle comes back and gets worser and worst, what can i do to fix this ? Maybe heat is loosening it ? should i heatwrap portion of my exhaust where it passes below the shifter ???
Old Jan 10, 2007 | 10:02 PM
DraginTeg93's Avatar
Default Re: shifter bolt gets loose ! (Extreez)
try locktight
Old Jan 10, 2007 | 10:03 PM
Extreez's Avatar
Default Re: shifter bolt gets loose ! (DraginTeg93)
wont that be permanate
Old Jan 10, 2007 | 10:08 PM
numbnuts22715's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez &raquo;</TD></TR><TR><TD CLASS="quote">wont that be permanate</TD></TR></TABLE>
no, you can get it off, its just a little bit harder. Another thing you may want to try to do is to tighten another nut on the bolt right next to the nut that keeps coming loose. After you get it tight, turn the two nuts in opposite directions to get it even tighter, This is what I did when I installed my short shifter because my nut kept falling off.
Old Jan 10, 2007 | 10:32 PM
Extreez's Avatar
Default Re: shifter bolt gets loose ! (numbnuts22715)
i heard its bad if i tighten it too much true or not true lol
Old Jan 10, 2007 | 10:34 PM
anything can be bad if it's tightened too much. If you tighten a nut too tight, the bolt can snap. Apply lock-tight, get it snug, and tighten another nut up to the first one, then losen the first one back so the first and second nuts are extremely tight to eachother.
Hope this helps
Old Jan 10, 2007 | 10:35 PM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">anything can be bad if it's tightened too much. If you tighten a nut too tight, the bolt can snap. Apply lock-tight, get it snug, and tighten another nut up to the first one, then losen the first one back so the first and second nuts are extremely tight to eachother.
Hope this helps</TD></TR></TABLE>
Beat me to it.
Old Jan 10, 2007 | 11:02 PM
Extreez's Avatar
Default Re: (numbnuts22715)
hmm so u mean apply lock tite and attach the 2 bolts together ?
Old Jan 10, 2007 | 11:11 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: (Extreez)
hmm so u mean apply lock tite and attach the 2 bolts together ?</TD></TR></TABLE>
put lock tight on the first bolt tighten it pretty tight. put lock tight onto a second bolt tighten it but not quite as tight then loosen the first one (threading it as if you're removing it.) so it's tight against the second bolt. therefore leaving enough slack in the shifter so that you can still move it. and securing the bolt in place.
Old Jan 11, 2007 | 12:00 AM
Default Re: (god.loves.ugly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by god.loves.ugly &raquo;</TD></TR><TR><TD CLASS="quote">
put lock tight on the first bolt tighten it pretty tight. put lock tight onto a second bolt tighten it but not quite as tight then loosen the first one (threading it as if you're removing it.) so it's tight against the second bolt. therefore leaving enough slack in the shifter so that you can still move it. and securing the bolt in place. </TD></TR></TABLE>
Thank you! much better way of explaining it. I couldn't think of the words to explain it as well as you did.
Gant
Jan 5, 2008 09:54 PM
red-teg!
Apr 11, 2007 07:27 AM
Tonyl507
Nov 6, 2006 08:09 AM
themorphious
Mar 7, 2006 09:47 AM
