Do integras have exhaust bolts or studs?
Old Jan 9, 2007 | 05:18 PM
spoolin_teg's Avatar
Default Do integras have exhaust bolts or studs?
My 97 integra ls has exhaust manifold bolts, I was thinkin and pretty much every other car i've worked on had exhaust manifold studs...Since I have bolts, it seems to strip out the head threads. which sucks. Where can I get studs?
Old Jan 9, 2007 | 05:25 PM
Runnerdown's Avatar
Default Re: Do integras have exhaust bolts or studs? (spoolin_teg)
early b-series had all studs for the exhaust flange. In later years such as your 97 they started using mostly bolts. This is cheaper for the manufacturer and saves them a few pennys per engine. Only the two outside holes have studs right?
I like to use full studs like they used to come from the factory.
Old Jan 9, 2007 | 05:27 PM
Default Re: Do integras have exhaust bolts or studs? (Runnerdown)
yeah, only the end 2. So I could go to ACURA and get studs?
Old Jan 9, 2007 | 05:31 PM
black98gsr-t's Avatar
acura or honda.... most b-series ive seen have the two outer as studs. just order as many of those as u need and also the nuts... honda maybe cheaper even though its the same part..
Old Jan 9, 2007 | 05:34 PM
Runnerdown's Avatar
Yeah you could get the rest right from acura, but they are expensive. About 2-3 bucks each for the stud and another 1.50-2 each for the oem locking nuts! I usually take them off old motors before they get scraped!
Old Jan 9, 2007 | 05:53 PM
yeah...i guess i could do that. thanks guys
sleepencivic
Mar 22, 2011 06:39 PM
90Integra_Rs
Jan 12, 2007 08:39 PM
Turbo_Mike
Sep 8, 2005 12:03 PM
Jared
Aug 8, 2003 07:39 PM
Rain_man
Feb 4, 2003 11:27 PM
