-10 AN oil return line, oil pan adapter
Old Jan 9, 2007 | 02:42 PM
jdmsiR20's Avatar
Default -10 AN oil return line, oil pan adapter
planning on using a -10 AN bulkhead adapter on my oil pan. i know alot of people will suggest welding it in, but in the absence of time i may do it this way, with JB weld.
its been asked before, but just want confirmation that this is the correct part i need. thanks
http://store.summitracing.com/...w=sku
can anybody suggest anything else cheaper?
Old Jan 9, 2007 | 04:54 PM
dpetro1's Avatar
Default Re: -10 AN oil return line, oil pan adapter (jdmsiR20)
yeah i guess you could use that. does the nut attach on the back on the inside of the pan? i originally was gonna use something like that but realized you start to run out of room to thread the nut on once you get through the pan and washers.
take a look at this thread. go about half way down the first page, look for username Sonny. i followed this method and it has worked flawlessly for 1 1/2 years. no messy jb weld either.
https://honda-tech.com/zerothread?id=415678
he used a fitting like this. its cheaper too.
Old Jan 9, 2007 | 04:56 PM
cherryhatch00's Avatar
Mine is shitty. I've just got a peice of 3/4" steel welded into the pan and have to use rubber return lines.
I plan on either patching my current oil pan or buying a better oil pan and getting a threaded fitting so I can use braided lines..
I assume braided lines ARE better. Yes?
Old Jan 9, 2007 | 05:20 PM
sc4dr's Avatar
Default Re: (cherryhatch00)
I'm running a rubber return line, no problems. Stainless does look better though.
Old Jan 9, 2007 | 05:22 PM
I melted mine after running open downpipe that didn't make it quite under the car.
Fried ze turbo.
Old Jan 9, 2007 | 05:26 PM
black98gsr-t's Avatar
Default Re: -10 AN oil return line, oil pan adapter (dpetro1)
[/QUOTE].
this is what came with my peakboost kit, ive yet to install it but from pics ive seen people using it looks like a good fit.. id put the short side inside the pan that way u can keep tabs on how tight the nut is from the outside.. also use the flat nylon washers on each side of the pan..
Old Jan 9, 2007 | 05:34 PM
Looks a little short..
Of course the pic is tiny.
Old Jan 9, 2007 | 05:45 PM
the thickness of the oil pan is maybe 1/16" and with the two washers (one on each side) its prolly about 3/16" total thickness..
Old Jan 11, 2007 | 09:04 AM
dpetro1's Avatar
Default Re: -10 AN oil return line, oil pan adapter (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">
this is what came with my peakboost kit, ive yet to install it but from pics ive seen people using it looks like a good fit.. id put the short side inside the pan that way u can keep tabs on how tight the nut is from the outside.. also use the flat nylon washers on each side of the pan.. </TD></TR></TABLE>
yeah if you look at the thread i posted, thay guy cut the short end off and then put it though the inside of the pan, washers on each side, nut on the outside. there is plenty of room left fo the stainless line to attach.
B18c1turboedEK
Feb 21, 2005 10:32 AM
EkHatch1
Dec 9, 2004 08:25 PM
Sinner
Oct 8, 2004 09:21 AM
420aNT
Mar 9, 2003 10:26 PM
Evil EG
Apr 3, 2002 07:30 PM
