Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken?
Old Jan 7, 2007 | 10:43 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken?
I had a good bit of problems this year with boost not staying steady, I ran a 14psi spring which is about the psi level I wanted to run but sometime it would skyrocket and sometimes it would build boost rather slow
Is there a tech guide to taing these units apart and inspecting them.
Just curious if maybe its sticking open and causing me to build boost very slowly
Old Jan 7, 2007 | 11:29 AM
Boosted B6teen's Avatar
Default Re: Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken? (PINKS)
http://www.tialsport.com/techincal.htm
They have some diagrams there that will help you
Old Jan 7, 2007 | 11:33 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">I had a good bit of problems this year with boost not staying steady, I ran a 14psi spring which is about the psi level I wanted to run but sometime it would skyrocket and sometimes it would build boost rather slow
Just curious if maybe its sticking open and causing me to build boost very slowly</TD></TR></TABLE>
check diaphragm first. i had nothing but problems with tial wastegate. diaphragm ripped twice
Old Jan 7, 2007 | 03:07 PM
PINKS's Avatar
bump for more info
Old Jan 7, 2007 | 04:50 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">How To Tell If My Unit Is Broken?</TD></TR></TABLE>
LOL
Old Jan 9, 2007 | 02:33 AM
PINKS's Avatar
Old Jan 9, 2007 | 05:41 AM
vtec.dc2's Avatar
Default Re: Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
check diaphragm first. </TD></TR></TABLE>
did you inspect the diaphragm? thats more than likely is the problem. or vaccum lines are loose/leaking
Old Jan 9, 2007 | 09:53 AM
rmcdaniels's Avatar
Open it up, mine was very easy to take apart and inspect. I found that the diaphragm was installed incorrectly, one of the expansion folds was getting pinched where the housing screws together. I installed it correctly and it worked fine.
Old Jan 9, 2007 | 12:08 PM
PINKS's Avatar
Default Re: Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken? (rmcdaniels)
Old Jan 10, 2007 | 11:51 AM
PINKS's Avatar
Old Jan 11, 2007 | 02:35 AM
PINKS's Avatar
Default Re: Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken? (Boosted B6teen)
Old Jan 21, 2007 | 01:09 PM
PINKS's Avatar
I just pulled apart my wastegate, there might be something wrong
The diaphram is kind of crinkled, kinda pushed down in one spot
Doesnt seem to be ripped though but the diaphram is probably permantently in that position
Need pics? What should I do?
Old Jan 21, 2007 | 02:40 PM
rmcdaniels's Avatar
That's how mine was. I just reassembled it carefully, poking the fold in the diaphragm inside the casing with a feeler guage as I screwed it together to keep it from getting pinched. Mine worked fine after that.
Old Jan 21, 2007 | 04:32 PM
PINKS's Avatar
Mine seems pinched not where the casing closes down though, its on the raised lip that goes on the innermost wall of the top of the diaphram, dunno why it was like that
If theres no rips its good to go?
Old Jan 22, 2007 | 02:27 AM
PINKS's Avatar
Old Jan 22, 2007 | 01:12 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Mine seems pinched not where the casing closes down though, its on the raised lip that goes on the innermost wall of the top of the diaphram, dunno why it was like that
If theres no rips its good to go?</TD></TR></TABLE>
that diaphragm is supposd to strech.. not as in material but extend. when i took mine apart, it was all pinched as well, so i had to extend it to see the damage. you have to inspect entire diaphragm.. pics would help before you close it backup
igo4bmx
Aug 4, 2006 06:53 AM
turbodan4
Mar 7, 2006 09:09 PM
turbo95eg6
Jun 12, 2005 07:46 PM
DLB1994
Jan 25, 2004 11:03 AM
G U E C O
Dec 9, 2003 02:43 PM
