battery question?
i have a 00' SI with the stock battery, and the eye that's supposed to be green to check the battery is not. I haven't had any problem but sometimes in the cold the car takes a while to start. should i change it or keep it? also what brand of battery
do you recommend.
do you recommend.
it get's around 20 to 30 degrees. and it usually takes no more than 2 seconds because i leave it in start first for a second or two. also the optima battery looks like it won't fit will it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">how cold does it get there and how long does it take to crank it over? I've heard good things about Optima</TD></TR></TABLE>
they are junk.
they are junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">
they are junk.</TD></TR></TABLE>
I've heard good things about optima as well why do you say they're junk? which one do you recommend?
they are junk.</TD></TR></TABLE>I've heard good things about optima as well why do you say they're junk? which one do you recommend?
Cruse over to your local checker, schucks or autozone and have them test the battery for free, there setup will usually catch a battery that's on it's way out before it turns into a problem for you.
yeah that's what i'm going to do tommorrow, but they are probably going to say it's bad that's why i started looking for optimas but my size is sold out in all the stores i've searched what's other good brand?
Ruben19
11
Sep 11, 2008 07:12 PM
GreenMachineRex
May 1, 2004 03:27 PM
