12- EGR - exhaust gas recirculation lift valve
Old Jan 2, 2007 | 04:04 PM
smokey2.0's Avatar
Default 12- EGR - exhaust gas recirculation lift valve
does anyone have any idea, of how to correct this code? i did search, but got no answer. if you have any clue on this, please let me know!
Old Jan 2, 2007 | 07:58 PM
RCautoworks's Avatar
Default Re: 12- EGR - exhaust gas recirculation lift valve (smokey2.0)
Code 12 - Exhaust Gas Recirculation System
Mounted on the right back corner of the fire wall. It cannot be purchased seperatly, but only as a unit. Voltage range of the lift sensor is 1.2v closed to 4.0v open. It was required on all cars sold in in CA. starting in 1988. However, some CIVIC's were engineered without having to use one, to control NOx.
Purge Control Wires:
1 Yellow/Black
1 Red/Yellow
Back
Try cleaning it out
Old Jan 3, 2007 | 12:33 AM
smokey2.0's Avatar
Default Re: 12- EGR - exhaust gas recirculation lift valve (90blackcrx)
i'll try to clean it, can it be taken off?
Old Jan 3, 2007 | 01:06 AM
KFBhonda's Avatar
yes it can be taken off.
Old Jan 3, 2007 | 03:35 AM
HT Chaplain's Avatar
Loved
i have the same problem How can you eliminate the code???
Old Jan 3, 2007 | 05:49 AM
smokey2.0's Avatar
Default Re: 12- EGR - exhaust gas recirculation lift valve (HT Chaplain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem How can you eliminate the code???</TD></TR></TABLE>i guess by either cleaning it or taking it off, i'll find out tonight when i try cleaning it!
Old Jan 3, 2007 | 09:55 AM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">i guess by either cleaning it or taking it off, i'll find out tonight when i try cleaning it!</TD></TR></TABLE>
i made a fuel saver and did a MPFI conversion in my STD so i could use my old HF motor and the STD doesnt have a way to hook up the EGR
Old Jan 3, 2007 | 03:27 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">i made a fuel saver and did a MPFI conversion in my STD so i could use my old HF motor and the STD doesnt have a way to hook up the EGR </TD></TR></TABLE>post some pictures, i probably won't have any time to play with this until the weekend!
willpell
Dec 12, 2006 11:48 AM
93sleeper
Feb 20, 2005 08:03 PM
diewX3
Jan 26, 2005 09:22 AM
sytema
Jul 6, 2003 09:43 PM
B16edCRX
Apr 4, 2002 12:30 PM
