T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6?
Old Dec 30, 2006 | 08:41 PM
Tippyman's Avatar
Default T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6?
Gonna be boosting a built A6 next summer. Arias pistons, eagle rods, etc. Would a Garrett T3/T4, 0.48/0.50 A/R, 50 trim be good for my SOHC is my power goals are to hit an easy 300 hp?
I don't wanna be maxing out the turbo, I want a nice, conservative 300 while not having to spool up at 5000.
Old Dec 30, 2006 | 09:07 PM
CRXdan's Avatar
Default Re: T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6? (Tippyman)
It s ounds liek a good match.
I have a .63 AR on my sohc and spool is quite late, although with a built topend and higher revving motor it woudl be essential.
Old Dec 30, 2006 | 09:23 PM
Tippyman's Avatar
Default Re: T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6? (CRXdan)
I'l be shifting at 6500.
Old Dec 31, 2006 | 06:47 AM
Tippyman's Avatar
ttt
Old Jan 1, 2007 | 12:06 PM
HiProfile's Avatar
Default Re: (Tippyman)
If you're lucky, you'll get 2000 rpm of full boost. The turbo I used would probably be perfect. Its a t3/t04B s-trim (in between t3 60trim and t3/t4 50trim) with a .48 stg1 exhaust. On a stock d16z6 and full 3" dp/exhaust I build boost after 3k and 10psi after 4k. The s-trim can take you to 300whp easy if you're able to tune past 11psi.
Old Jan 1, 2007 | 12:13 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I'l be shifting at 6500.</TD></TR></TABLE> Stock cam? With a SOHC you can take it into the 7'k
Old Jan 1, 2007 | 04:49 PM
Tippyman's Avatar
Default Re: T3/T4, 0.48/0.50 A/R, 50 trim: Good match for my little A6? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Stock cam? With a SOHC you can take it into the 7'k</TD></TR></TABLE>
Well, SOHC ZC cam. I'm having the Head worked over by Endyn. (stock rebuild w/ mild p&p.) When I shift, it drops a little below 5k, so as long as it's in full boost by then I'll be ok.
Old Jan 1, 2007 | 05:56 PM
Tippyman's Avatar
ttt
spoolin turbo s
Oct 19, 2008 05:18 PM
pjr710
May 10, 2007 07:12 PM
LU
Feb 22, 2007 10:45 PM
turboeg77
Oct 27, 2005 08:46 AM
DreamCatcher
Jun 22, 2005 11:45 AM
