EG swap Question..
Old Dec 29, 2006 | 08:56 PM
EM1OwnerSi's Avatar
Default EG swap Question..
Alright i have motor from a Em1 b16a2 that im about to swap into my EG..Would it be alright if i convertt he motor to an obd1 by changign the dizzy,ecu, and harness.. or just leave it obd2.. i have a ecu already and dizzy....HELP GUYS
Old Dec 29, 2006 | 09:05 PM
BlueIntegraBoy's Avatar
Default Re: EG swap Question.. (EM1OwnerSi)
Yes, you can convert it to OBD1. Don't forget the injectors. On the other hand, if you keep the dizzy, etc. OBD2, you'll need an OBD2 Integra harness, then run a jumper harness to OBD1.
Old Dec 29, 2006 | 09:26 PM
EM1OwnerSi's Avatar
Default Re: EG swap Question.. (BlueIntegraBoy)
so to convert it 2 obd1 what is all needed?'
ECu
Dizzy
Which Harness?
obd1 injectors
Am i missing anything else
Also what axles would u recommend
Old Dec 30, 2006 | 12:43 AM
To make things really easy, any harness from a 94-95 GSR or 94-95 Del Sol VTEC. A harness from a 92-95 EX/Si will work too, but you will need to add in a knock sensor.
Any USDM hydro b-series axle will work with this swap, so the ones from the B16A2 will work.
Old Dec 30, 2006 | 07:31 AM
EM1OwnerSi's Avatar
THANKS A BUNCH MAN
Old Dec 30, 2006 | 07:43 AM
EM1OwnerSi's Avatar
o ya is there a certain ecu u would recommen?
Old Dec 30, 2006 | 10:17 AM
P30
Old Jan 5, 2007 | 09:27 PM
EM1OwnerSi's Avatar
jaap_15
40
Mar 10, 2011 07:44 PM
B16a2Wa
18
Jan 24, 2010 08:10 PM
wacohnda_rider
Aug 18, 2009 10:19 PM
pnoyboldstar
Apr 13, 2007 09:13 AM
DFW
Apr 30, 2006 07:37 PM
