3rd BROKEN CAT! what should i check now
i have a 1998 honda civic lx auto
w/y8 IM, I/H/E and 110k miles on the little y7. This is the third broken cat since my distributer started acting up. Replaced the dist. then it went about 1/2 a year before it is broken again. WHat causes a CAT to break completely. These are not cheapo cats either two Magnaflows and one carsound. What should i start to look for.
How do they break? Also, did you remove the stock Y7 exhaust manifold and cat which made you get an aftermarket cat?
Broken=loose metal in the CAT. Converter. No it is not broken off the car, it has no flanges to bolt to. I had it welded on.
u fitted a new dizzy latley? ur timing cud be wrong and unburnt fuel is getting into the exhaust system,this will cause the cat to over heat and break up.get it checked with a strobe timing light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyhamsterlx »</TD></TR><TR><TD CLASS="quote">what are the benefits of using an OEM Cat? </TD></TR></TABLE>
Maybe it wont break.
