In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use
Old Dec 27, 2006 | 01:23 PM
crazy_ace_civic's Avatar
Default In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use
well i don't no much about my honda i just got it and win i step on the gas it almost dies on me it running 30psi my o2 is not in the down pipe and should i get a performance distributor and what kind will on D16A6 email me thanks
Old Dec 27, 2006 | 01:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use (crazy_ace_civic)
ok i am making no assumptions on this one.
i will offer 2 scenerios.
1 - smart *** scenerio:
stocks are fine and all you need is a 14:1 fmu. and youll be fine. stock pump will flow plenty.
2 - non smart *** scenerio:
that much boost is too much for a stock bottom end, you need your o2 in the d.p. and the cc's depend on your power goal. also to run more than stock, you will need a chipped ecu or some form of management.
Old Dec 27, 2006 | 01:52 PM
Default Re: In my 91 hatchback i got t3/t4 turbo what kind of cc injecters should i use (boostedcivicsir)
the bottom end is done but i don't know what they got in it if want to see pics go http://www.myspace.com/crazyhatchbackcivic and how do u put in a block guard
Old Dec 27, 2006 | 02:11 PM
Mr. Badwrench
correctly should be done before it is honed, but i have talked to a few people and the general consensus is to leave it out.
what trim is the turbo and housing size?
Old Dec 27, 2006 | 02:31 PM
60 trim
Old Dec 27, 2006 | 02:35 PM
Mr. Badwrench
wonder how hot the air coming out of it is.
put some 750's in it and go from there and get it tuned.
Old Dec 27, 2006 | 02:40 PM
thanks
Old Dec 27, 2006 | 03:45 PM
1988-1991 Honda/Acura - Must remove OEM resistor box and use OBD1 style injector connecting plugs rc 750cc
Old Dec 27, 2006 | 03:48 PM
Mr. Badwrench
get peak and hold injectors
or remove it, jump the wores, and use saturated injectors.
Old Dec 27, 2006 | 05:49 PM
9200RPM's Avatar
your lucky you didnt throw a rod through the bottom end running a setup like that....i hate to be that guy but that car is the ugliest thing i have ever seen....
4cyl707
Nov 17, 2009 03:46 PM
EJ8 GSR-T
Mar 28, 2006 04:09 AM
JonnyCoupe
Mar 22, 2005 01:05 AM
t3eg
Jan 29, 2003 05:20 AM
-CP-
Aug 8, 2002 04:40 AM
