D16A6/D16Y8 Mini Me Swap
Old Dec 26, 2006 | 03:03 PM
flatblack-h22's Avatar
Default D16A6/D16Y8 Mini Me Swap
A6 Block
A6 Waterpump
Y8 Head
Y8 Timing Belt
would the timing be off with this setup? is an adj cam gear needed? LMK asap. car is not starting
Old Dec 26, 2006 | 03:13 PM
dr_latino999's Avatar
Default Re: D16A6/D16Y8 Mini Me Swap (mr.EGg)
No cam gear is needed if you are using the cam gear that matches the cam. BTW, are you using the Y8 tensioner as well for the timing belt?
Old Dec 26, 2006 | 05:08 PM
Global688's Avatar
Im still using the stock Y8 cam gear with the stock A6 botom end. Timing stays off a bit and I burn more oil, but it works as the DD.
Can we have more info?
year make model, ecu, and a better explanation of the issue other than the car doesnt start?
Old Dec 26, 2006 | 05:27 PM
Default Re: D16A6/D16Y8 Mini Me Swap (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">No cam gear is needed if you are using the cam gear that matches the cam. BTW, are you using the Y8 tensioner as well for the timing belt?</TD></TR></TABLE>
no clue of what cam is in there, but i believe its stock and its also a Y8 cam gear. i'm also using the tensioner that came with the swap when i bought it and replaced the belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Global688 &raquo;</TD></TR><TR><TD CLASS="quote">Im still using the stock Y8 cam gear with the stock A6 botom end. Timing stays off a bit and I burn more oil, but it works as the DD.
year make model, ecu, and a better explanation of the issue other than the car doesnt start?</TD></TR></TABLE>
92 Honda Civic, P28, P30. try to start the car, but wont sound. sounds like it wants to but it just keep cranking.
Old Dec 26, 2006 | 05:39 PM
Global688's Avatar
Try checking your spark plug order off the dizzy. Make sure your fuel injectors are spraying.
Old Dec 26, 2006 | 05:42 PM
Default Re: D16A6/D16Y8 Mini Me Swap (Global688)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Global688 &raquo;</TD></TR><TR><TD CLASS="quote">Try checking your spark plug order off the dizzy. Make sure your fuel injectors are spraying.</TD></TR></TABLE>
3 4
1 2
i believe they are spraying because i took it off to clean them and they was wet
Old Dec 26, 2006 | 05:48 PM
Global688's Avatar
Are you using the Y8 ob2 dizzy or your stock one? Might want to check your wiring. Also sounds dumb but have somone give you a jump. Wouldnt belive how often that little *** car battery wont turn over the engine...
Old Dec 26, 2006 | 06:12 PM
http://img213.exs.cx/img213/8465/ch3px.jpg
which 2pin goes to the FITV and the peice on the right by the TB?
red yellow/black
yellow black/blue
using a Z6 dizzy at the moment. i would jump start it, but then i wouldnt be able to get back up my hill to the garage
Old Dec 27, 2006 | 03:12 PM
SINGLECAMAN's Avatar
what ecu?? you need a obd1 ecu with the obd1 dizzy you can use an a6one with the pm6 ecu though ..ohh my bad you are aware of it good luck
Old Dec 27, 2006 | 04:28 PM
schardbody's Avatar
you need an adjustable cam gear to get timing perfect, requires -4.5 degrees for the Y head on any other block because of the offset of the Y cam and sprocket keyway.
this may not be the problem but figured i would let you know. also, check for spark, you never said if you did or not.
Old Dec 28, 2006 | 02:23 PM
Default Re: D16A6/D16Y8 Mini Me Swap (SINGLECAMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINGLECAMAN &raquo;</TD></TR><TR><TD CLASS="quote">what ecu?? you need a obd1 ecu with the obd1 dizzy you can use an a6one with the pm6 ecu though ..ohh my bad you are aware of it good luck </TD></TR></TABLE>
z6 dizzy w/ p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">you need an adjustable cam gear to get timing perfect, requires -4.5 degrees for the Y head on any other block because of the offset of the Y cam and sprocket keyway.
this may not be the problem but figured i would let you know. also, check for spark, you never said if you did or not. </TD></TR></TABLE>
got spark, cuz i got shocked. got it started for a bit but had to keep it rev so it would die. but ill get one of those
Old Dec 28, 2006 | 02:41 PM
mengy007's Avatar
Default Re: (schardbody)
would that be retard or advance? I have the same setup. d16a6 block with d16y8 head. I used the y8 belt and I have an adj. cam gear. Right now I have it set 4degrees advanced. It runs strong down low but is lacking above 5k but that might be because I don't have vtec hooked up yet.
Old Dec 28, 2006 | 05:23 PM
schardbody's Avatar
Default Re: (mengy007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote">would that be retard or advance? I have the same setup. d16a6 block with d16y8 head. I used the y8 belt and I have an adj. cam gear. Right now I have it set 4degrees advanced. It runs strong down low but is lacking above 5k but that might be because I don't have vtec hooked up yet.</TD></TR></TABLE>+
sorry, if you use the A6 gear it will be perfect. using the y8 cam gear will retard it 4.5 degrees.
xmd
Feb 4, 2019 07:01 AM
austen95
Mar 12, 2018 06:55 PM
90ZCREX
Jun 14, 2011 04:10 AM
O16581724 5 2 5
17
Jun 30, 2006 03:16 PM
rass1313
Mar 14, 2005 11:20 AM
