H22 owners your impression of .82 turbine, too big or reasonable?
Old Dec 23, 2006 | 05:56 AM
jetlude's Avatar
Default H22 owners your impression of .82 turbine, too big or reasonable?
Repalcing my .63 turbine 57trim t3/t4. Got a deal on a t3/t04e .82 turbine with 60-1 wheel compressor. My engine is built .
Did I make a good choice????
Modified by bradboy at 12:31 AM 12/27/2006
Old Dec 23, 2006 | 06:15 AM
DaveF's Avatar
Default Re: H22 owners your impression of .82 turbine, too big or reasonable? (bradboy)
yea
Old Dec 23, 2006 | 12:54 PM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradboy &raquo;</TD></TR><TR><TD CLASS="quote">Repalcing my .63 turbine 57trim t3/t4. Got a deal on a t3/t04e .82 turbine with 60-1 wheel turbine. My engine is built .
Did I make a good choice????</TD></TR></TABLE>
Were you not satisfied with .63/ 57trim? What numbers were you making with that turbo?
I recently got my t3/t4 .63a/r 60 trim looking to make anywhere between 350-400whp.
Old Dec 23, 2006 | 02:05 PM
b16hybridsol's Avatar
Default Re: H22 owners your impression of .82 turbine, too big or reasonable? (Team_Carnage)
i loved my 82, but i like my 1.06 better
Old Dec 26, 2006 | 03:55 PM
jetlude's Avatar
Ok the turbo(t3/t04e with 60-1 wheel .82 stage 3 turbine) is now the car (H22) but I am very dissapointed with the output. I know that the car is making alot less power now than with my old turbo (t3/t4 57 trim comp. .63 stage 3 turbine) at the same boost level. I expected to just have a later spool, but even more power up top, but this not the case.
Is there any way that I can regain the power with this turbo?
Please give advice.
Old Dec 26, 2006 | 04:23 PM
B18C1CYA's Avatar
Default Re: (bradboy)
did you retune it ???
Old Dec 27, 2006 | 01:54 AM
jetlude's Avatar
Default Re: (B18C1CYA)
yea did a bit of tuning but no difference....... I am getting about 15 psi at 4500 rpm and the wheels wont even get loose. I feels like the cams remain on low lobe right through almost like no vtec .
Old Dec 27, 2006 | 03:49 AM
Mr.60trim's Avatar
Default Re: (jetlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude &raquo;</TD></TR><TR><TD CLASS="quote">yea did a bit of tuning but no difference....... I am getting about 15 psi at 4500 rpm and the wheels wont even get loose. I feels like the cams remain on low lobe right through almost like no vtec .</TD></TR></TABLE>
What program are you running? Did you dyno tune or street tune or did both?
Old Dec 27, 2006 | 05:52 AM
jetlude's Avatar
Default Re: (Team_Carnage)
Actually ecu is stock .....I use a vortech fmu with larger injectors (4:1 ratio) plus HKS aditional injector controller running 2x 720cc independently . This work well (385 at the wheels 14psi) till the day I changed the turbo.
Old Dec 27, 2006 | 05:59 AM
93supercoupe's Avatar
WTF??Get a areal EMS and then report back w/ a 600hp H22
Old Dec 27, 2006 | 06:01 AM
N20civicB18's Avatar
Default Re: (93supercoupe)
haha i thought you said you did tuning?
check out neptune/hondata/crome/uberdata....
Old Dec 27, 2006 | 06:32 AM
jetlude's Avatar
Default Re: (N20civicB18)
Point well taken, will be doing that soon..........Question though. This setup worked well with my old turbo, should I not even be getting the same power with the .82 turbine or even close to it?
Modified by jetlude at 4:36 PM 12/27/2006
Old Dec 27, 2006 | 06:34 AM
Mr.60trim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">WTF??Get a areal EMS and then report back w/ a 600hp H22 </TD></TR></TABLE>
lol...yea seriously you should be making some major power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude &raquo;</TD></TR><TR><TD CLASS="quote">Point well taken, will be doing that soon..........Question though. This setup worked well with my old turbo, should I not even be getting the same power with the .82 turbbine or even close to it?</TD></TR></TABLE>
You should have more top end power. Spoolin' wise it might be a tad bit slower nothing to be worried about though. But definately get a real ems.
Old Dec 27, 2006 | 07:49 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude &raquo;</TD></TR><TR><TD CLASS="quote">Point well taken, will be doing that soon..........Question though. This setup worked well with my old turbo, should I not even be getting the same power with the .82 turbine or even close to it?
You will make much more power with your new turbo. You will not be able to utilize it though until you properly tune the engine. Without an ems you are just asking to blow your motor up.
4rthgencord
Feb 9, 2007 11:56 AM
mrx
Sep 3, 2005 11:27 AM
kriptik
Feb 18, 2005 11:04 AM
TurboJesse
Mar 24, 2003 07:27 PM
B20bTurbo
Nov 22, 2002 03:39 PM
