is AR from A T3 and a T3/T04 compareable?
Old Sep 3, 2005 | 01:47 AM
mrx's Avatar
mrx
Default is AR from A T3 and a T3/T04 compareable?
Hi,
sorry for that stupid question but i want to go for sure...
if i have a T3 Turbo with a given turbine AR... let's say 0.48
and a T3/T04E with a turbine AR of 0.48...
can i expect from this that the turbine is exact the same? or is there a difference?
Thanks
Malte.
Old Sep 3, 2005 | 04:46 AM
Bailhatch's Avatar
Default Re: is AR from A T3 and a T3/T04 compareable? (mrx)
no.
They both use a T3 style turbine but the straight t3 usually has a std or stg1 one turbine. A hybrid usually has a stg 3 or 5 wheel.
The compressors are totally different too so the A/R could be the same but one could make 280 whp and the other 580.
Old Sep 3, 2005 | 11:27 AM
mrx's Avatar
mrx
Default Re: is AR from A T3 and a T3/T04 compareable? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">no.
The compressors are totally different too so the A/R could be the same but one could make 280 whp and the other 580.</TD></TR></TABLE>
the thing with the turbine wheel is clear... but normaly (i know there are both, compressor and turbine AR) the turbine AR is mentioned when talking about ARs so the compressor should make no difference for the turbine ar between a T3 and a T3/04 or?!?
that it is possible to make more power with a hybrid is clear... would be bad if not ;-)
the question was only about the turbine configuration... but when the wheel is a different then the effect would be different... thats true... so as you wrote... short its not compareable...
thanks...
cleanej2
Mar 8, 2007 05:06 AM
kriptik
Feb 18, 2005 11:04 AM
B18c1turboedEK
Nov 24, 2004 10:56 PM
B20bTurbo
Nov 22, 2002 03:39 PM
