Dimmer Switch fried, WTF?
Old Dec 22, 2006 | 02:41 PM
JDM_d15b_eg8's Avatar
Default Dimmer Switch fried, WTF?
alright, i was at the junk yard today i remembered that i needed a dimmer switch cause mine didn't work, so i got one pulled the old one out and discovered that they had just jumped 2 of the 3 wires together to get them to turn on.
anyways before i left the junkyard i had installed the new dimmer and when i turned the car on i smelled burning electronics (yeah the dimmer switch) and at night i couldn't see anything cause my H.U.D. obviously wasn't working so i had to hot wire the dam thing again.
anyone know whats wrong??? did i just happen to get a wack dimmer switch from the J-yard?
Old Dec 23, 2006 | 03:34 PM
Default Re: Dimmer Switch fried, WTF? (JDM_d15b_eg8)
yeah i dont know whats going on, anyone got any info??
Old Dec 23, 2006 | 07:32 PM
john666's Avatar
i would think something like a dimmer switch doesnt go bad usally.. do you have anything else connected to the wires for the dimmer switch IE gauges, lights... perhaps you should look maybe thats what is messing them up
Old Dec 24, 2006 | 03:19 PM
Default Re: Dimmer Switch fried, WTF? (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">i would think something like a dimmer switch doesnt go bad usally.. do you have anything else connected to the wires for the dimmer switch IE gauges, lights... perhaps you should look maybe thats what is messing them up</TD></TR></TABLE>
yeah thats what i thought, but nah there is nothign there but the three wires for the switch, and the factory wiring harness was still there, looks like i'm gonna have to bust out the volt meter......sigh....i hate electrical troubleshooting...
Old Dec 24, 2006 | 05:28 PM
SaiLo's Avatar
Your's probably doesnt work because something shorted it out. Did you fix that problem yet? If not, you have to go back and fix the problem before you install the new dimmer.
The problem could be a grounded dimmer wire from your stereo.
Old Dec 25, 2006 | 06:15 AM
RyanA's Avatar
Default Re: (SaiLo)
If the factory stereo harness had been cut, I'd start there. On a few Hondas I have bought and the dimmer switch burned up, it was the previous owner that thought there were a "professional" installer, using wire nuts and scotch tape to install the radio.... On every car I get with any harness cut, I go to the salvage yard and get one that is uncut and simply install it. It's fixed it every time....
Harnesses at the salvage will be between 15 and 40 bucks. It goes all the way over to the fuse box and usually runs the instrument cluster, radio, hazard, etc.
Ryan
Old Dec 26, 2006 | 05:17 AM
94WhYt_EG1's Avatar
yeah that same **** happened to me...except i fried it. if your climate control doesn't light up either, than its the dimmer switch. i jus repaced mine and everything works now.
eL_cArLos
Feb 20, 2008 06:19 PM
SigmaOmega
Jul 17, 2005 06:55 PM
Mini-mEK4
Audio / Security / Video
Oct 19, 2004 01:25 PM
Denny
Jul 8, 2003 09:31 PM
5 watt
Jul 5, 2002 12:07 PM
