10.5 compression
Old Dec 21, 2006 | 06:42 AM
slowcrx954's Avatar
Default 10.5 compression
i am going ls/vtec and boost with a gt28 looking for as much power that turbo will push.and i want to do it all on 93 oct. With 10.5 will i be good on pump gas on like.How high compression are perple running safe on pump gas.ALL INPUT WELCOME!
Old Dec 21, 2006 | 08:15 AM
purpleh22's Avatar
Default Re: 10.5 compression (slowcrx954)
As you know, lots of turbo 'kits' are running 8-10 psi on engines with 10:1 comp. A number of them don't have very sophisticated engine management systems. Typically with this type of question, most of what I have heard is "Depends on the setup". It would be helpful to hear examples (setup, cr, boost level) whether or not the car is a daily driver and how long it has been running at that boost level.
Old Dec 21, 2006 | 09:44 AM
ExospeedAMcrx's Avatar
give a little more info. What bore size you planning to do?
10.5:1 is vague, the bore size can affect the piston design and compression.
an 81mm 10.5:1 will have a small dome vs an 84+mm which will be more of a flat top piston.
but as far as that compression, shouldnt be a problem as long as its fine tuned(like with any setup) We run over 30psi on our 84mm 10.9:1 motors.
Modified by exospeedAMcrx at 11:06 AM 12/21/2006
Old Dec 21, 2006 | 01:42 PM
slowcrx954's Avatar
thanks for the info and the car will be daily driven,and will have a standalone for the fine tune.also plan on turning down the boost when daily driving.and will be close to stock bore on a ls.
gs1gsr
Aug 19, 2012 05:42 PM
monster_c
Apr 6, 2012 02:14 PM
scspeed
Jul 24, 2008 03:53 PM
Turbo-GSR1287
Feb 10, 2008 03:11 PM
CXtypeR
Feb 28, 2007 10:44 PM
