I need help wit my headlights
I have 3-Buld projector Denji headlights, and the left headlight is out....I have checked the fuses and switch out the bulbs, it still doesn't work....The bright also work on the side, but the regular doesn't.....HELP ME...I feel like my car is a Blackbeard the Pirate or some s***
check the harness see it if the wires are loose.
are you using 100+watt bulbs if you are you might have fried your wires...
[Modified by B12uceHuy, 12:35 AM 5/13/2002]
check to see if the harness is connected, as they have a habit of working loose since they dont really 'click' together well...
I had the same type of problem one my accord. I just spliced into the side that worked conected a fuse and ran it to the side that didn't light.
Jago
Jago
OK everyone, I undid the harness and plugged it back together, that didn't work....And I'm only runnin' 70 watt lights....I'm pretty sure all three of the bulbs I tried to replace into the lights are good....So anymore ideas on what I can do??...I would run a wire and fuse from the working light, but my car is already held together wit random zip ties and ish, I don't really wanna jimmy rig it anymore....It's a good idea though.....Please if anyone has any other ideas post 'em, I really don't wanna spend the money to take it to a shop
92hatch420
Mar 6, 2006 06:16 PM
sockvtec
12
Oct 19, 2005 09:54 AM
