Lighting HID/Xenon kits, Retrofits and Associated Topics
Problem with headlights
Old Jan 9, 2012 | 11:39 AM
JDMin206's Avatar
Default Problem with headlights
I've had my EM1 for around 6 months now. Running Bi-xenon so I have high and low hids. Recently went I turned on my headlights, none of them would turn on. I checked all my fuses . ( i blew a 25A fuse for relay harness for the bi xenon) i replaced that. I blew a underdash 10A for (L Hi Light) i also replaced that. Also i even wanted to make sure, I replaced the 30A fuse under the hood for (Headlights) . It still wouldnt turn on. I don't know what it could be because I have other bulbs and HID Ballasts that I tried on. Any help would be greatly appreciated I work at night so I cannot drive without any headlights.
Edit : When i turn on switch for my headlights, my tailights light up fine. All my interior lights up fine. Brakes lights up. No problem just headlights not turning at ALL.
Old Jan 10, 2012 | 05:28 PM
Joon Joon's Avatar
Default Re: Problem with headlights
those kits are the worse kits.. the high really isnt even a high.. if you did a retro and had bixenons then ok yeah it would be good.. to get the lights to work, you might want to see if the ballasts will fire just connected straight to the battery.. if not then you have bad ballasts.. if you dont hear the relay clicking when you turn on your lights, that could also have gone bad..
Cuitarded
Honda Fit
Feb 19, 2014 02:33 PM
EF_ST@TUS
Aug 9, 2005 08:31 PM
nfiedler3
May 24, 2002 07:47 PM
e-lauckd
Aug 20, 2001 05:10 AM
