headlights stopped working wtf mate?
1 Post
ok so my headlights dont come one, everyhitng else works properly, what fuse is for the headlights? i checked the bulbs and they are ok and the connections are also ok so it must be the fuse....but the fuses underneath my dash have all been modified and split (first owner?) so i dont know what the correct fuse diagrams are....someone help so i can drive at night
Modified by sockvtec at 4:06 PM 10/18/2005
Imperious: Mod of Valor
Re: headlights stopped working wtf mate? (sockvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec »</TD></TR><TR><TD CLASS="quote">the bulbs are fine and so are the connections...
How do you know the bulbs are fine? Are you just assuming they're fine?
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">How do you know the bulbs are fine? Are you just assuming they're fine?</TD></TR></TABLE>
i pulled both out...they were fine (they are only a year old if that) also i checked the connections all the way to the fuse box...all connected, i just dont know what fuse if for the headlights cause my (underdash) fusebox was modified byt the 1st owner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamijdmcoupe524 »</TD></TR><TR><TD CLASS="quote">check the switch for the headlights. mine was broken on the inside once.</TD></TR></TABLE>
where exactly is that?
where exactly is that?</TD></TR></TABLE>
If you don't know where your headlight switch is, how do you know if they're working or not?
1 Post
Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 »</TD></TR><TR><TD CLASS="quote">The headlight fuse should be under the hood.</TD></TR></TABLE>
ok is it the 10 thats screwed down?
I do not have a picture of the fuse layout, but the headlight fuse is underneath your dash. They are 10AMPs.. 2 for lowbeams and 2 for high beams. The fuses are red and should be 4 lined up next to each other.
