3rd Gear Grind?
Hi i have a 94 civic 2 door 5 speed, and I have this annoying problem
Everytime i shift to 3rd gear, it feels like it grinds and makes a noise...i don't know much about this kinda stuff so i was wondering if you would wanna help
p.s. it doesn't grind if i double clutch
Ha, 3rd gear Syncros sound fucked.
If your tranny fluid is fine (full) then you can try GM syncromesh, that's up to you.
If that doesn't fix it, you can replace the syncros, but usually it's easier/cheaper just to get a new tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">try GM syncromesh</TD></TR></TABLE>
try this first. might help
If you have a '94 civic coupe like you're saying and you didn't mention that the engine was swapped, that means it has the original engine - that also means that that original engine is a D-series. That means that your current transmission will bolt right up to the JDM D15b w/o any problems.
Luchini
Dec 4, 2006 10:04 PM
i HAVEtheADVANtage
17
May 28, 2003 10:58 PM
