car idles at 2000 rpm when first started
Old Dec 17, 2006 | 08:45 PM
JoSi's Avatar
Default car idles at 2000 rpm when first started
ive been noticing that my car's idle goes to 2000 rpm every morning but then it goes down after like 2 minutes of leaving it running. i check all the vacuum hoses and they're all fine. it only really does it when its cold but it idles fine after its been warmed up. i think my temp sensor on the head might of gone bad. any ideas of what it might be?
Old Dec 17, 2006 | 09:05 PM
JakeSpec's Avatar
Default Re: car idles at 2000 rpm when first started (JoSi)
bad IAC valve
Old Dec 18, 2006 | 11:10 AM
ONEFASTJDM's Avatar
is this for carburated or fuel injected models?
Old Dec 18, 2006 | 12:38 PM
Ltsmith05's Avatar
Sounds like the motor is just warming up.
Old Dec 18, 2006 | 01:32 PM
ef-hatchcrap's Avatar
Default Re: (Ltsmith05)
Hondas idle high until they are warm then they will idle down. Its best to let it fully warm up before you drive it.
Old Dec 18, 2006 | 02:38 PM
IamEFinsweet's Avatar
Default Re: (ef-hatchcrap)
**** mine does the same thing but at 3000. it's really annoying, i was thinking cus i have a cheap *** OBX free flow cat on it. but thats my deal. I'd also like to know why mine is doing this. i have 1990 LS motor in it btw.
Old Dec 18, 2006 | 04:32 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: car idles at 2000 rpm when first started (JakeSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">bad IAC valve</TD></TR></TABLE>
X2 Agreed
Old Dec 18, 2006 | 04:38 PM
SupraRXZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ltsmith05 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the motor is just warming up.</TD></TR></TABLE>
same happens to me, but I just think of it as the engine warming up, and the idle goes lower as the temp rises
Old Dec 18, 2006 | 06:24 PM
crx_88_si's Avatar
2k is normal, 3k is not.
Old Dec 19, 2006 | 07:03 AM
Default Re: (crx_88_si)
yes it is very loud, obnoxious and i'm just ditching the motor anyway.
Old Dec 19, 2006 | 07:21 AM
redsolturbo's Avatar
Default Re: (IamEFinsweet)
2000rpm is pretty normal on pmgfi cars. (especially in cold climates/winter months etc)
my hondas have always started at around 2000-1700 rpm, stayed there for about 30 seconds then slowly brought them selves to idle. basicly your fitv valve is open and as the coolant temp raises the valve begins to close lowering your idle.
3000 rpm is NOT normal though
Old Dec 19, 2006 | 07:48 AM
zccr-xsi's Avatar
mine does same thing on start up idles at 2k then slowly goes down as it warms up.
Old Nov 28, 2025 | 03:18 PM
Deafboii_CRX_Si's Avatar
hello. My name is Christopher Maynard. Btw I’m deaf.. I need some ur help. It’s normal 2k rpm idle when cold start Honda Crx Si 1986.. when car was cold 2k rpm idle after was warming up drop 600-700rpm.. its would fine? Let me know please.. comment
freedomx101
23
Apr 11, 2008 11:16 PM
mike93eh2
Jul 17, 2007 07:45 PM
jdmstreethatch
13
Apr 5, 2004 11:09 AM
crx00
Mar 13, 2004 06:39 AM
baddboy
Sep 10, 2003 05:00 PM
