I HAVE A 95 CIVIC 4DR 1.5 . REPLACED THERMOSTAT, STILL OVERHEATS , ANY IDEAS
i RECENTLY REPLACED THE THERMOSTAT ON MY CIV AND ITS STILL OVERHEATING , THERES LOTS OF COLLENT IN THE RAD , AN I`M GONNA CHECK TO SEE IF THE FAN IS BUSTED , OTHER THAN THAT ANY SUGGESTIONS ON WHAT THE PROB COULD BE .
ANY RESONSE IS A GOOD ONE
THANKS
ClimbingBraydon
THANKS
ClimbingBraydon
FIRST OFF STOP YELLING turn off your caps lock. 2nd you might have an air pocket in the cooling system. Did you run the car with the radiator cap off the heat on full hot until the thermo opened up then.
Original problem would be nice to know. When does it overheat? All the time? When I stop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climbingbraydon »</TD></TR><TR><TD CLASS="quote">i RECENTLY REPLACED THE THERMOSTAT ON MY CIV AND ITS STILL OVERHEATING , THERES LOTS OF COLLENT IN THE RAD , AN I`M GONNA CHECK TO SEE IF THE FAN IS BUSTED , OTHER THAN THAT ANY SUGGESTIONS ON WHAT THE PROB COULD BE .
THANKS
ClimbingBraydon</TD></TR></TABLE>
i have a 99.9% feeling that Mr. Caplock didn't burb the system. OP, if you burb the system, your overheating problem will disappear.
THANKS
do a process of elimination .....check to see if your car radiator cap is still good....sometime the springs goes bad.... is top off.... check the overflow tank...upper and lower hose....did u bleed the system with the valve...did u installed the thermostat in the correct position....
hey man check your thermo switch by jumping it with a paper clip if the fan comes on then you either installed the thermostat wrong or you just left air in the system when refilling. IF there is air in the system all you need to do is fill the radiator to the max run the car and keep filling till the fans come on. Also you can check to see if the thermostat is opening by letting it run for a bit then check the temp. differance on the hoses going to the radiator. if the same the thermostat is opening if not after you run it for a while then it is not. hope this helps and you can back to driving.
thanks for the feedback , and sorry for caps , hahaha
I went ahead and blead the lines for air and it seemed to fix the prob , i think my rad might be going aswell so `im planning on replacing it
thanks for all the advice
Cheers
climbingbraydon
Cheers
climbingbraydon
