assembly lube?
Old May 11, 2002 | 01:29 PM
GreenD's Avatar
Default assembly lube?
can someone tell me a specific brand or something? i went to pep boys and all they could do was point me to was the gear oil
TIA
Old May 11, 2002 | 04:07 PM
martini's Avatar
Default Re: assembly lube? (GreenDestiny)
ask for anti-seize, and they will probably know what you are talking about.
Old May 11, 2002 | 05:35 PM
earl's Avatar
Actually some people use gear oil because it is so thick that it clings to the bearings until you get your oil pressure at the first start-up. I use something called Moly Assy Lube. Its like a black paste. Turns your oil black the first time. I like to spray WD-40 on the cyl. walls at the first start as it is so thin that it helps seat the rings quicker.
Old May 11, 2002 | 07:01 PM
clemens's Avatar
assembly lube for what? like for installing cams? go to a honda dealer...some techs call it pre lube as well
Old May 12, 2002 | 09:51 PM
Rocket's Avatar
Default Re: assembly lube? (clemens)
Clevite has a product called Bearing Guard. It's real thick and sticks like honey. Good ****.
[Modified by Rocket, 8:02 AM 5/15/2002]
Old May 14, 2002 | 10:41 PM
jetdriven's Avatar
Default Re: assembly lube? (Rocket)
i use the no-smoke treatment the sell at the parts store. motor-honey, bardahl's no-smoke, its all the same. its sold in a clear bottle and looks like honey. extra thick oil that clings to the bearings etc and protects during the first start up
Old May 15, 2002 | 01:14 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: assembly lube? (jetdriven)
I think BG makes a good assembly lube.
art
Old May 15, 2002 | 04:53 AM
bruthaboost's Avatar
Default Re: assembly lube? (earl)
This is the exact method I used and it has worked fine.
petty$rep
26
Jun 29, 2024 10:21 AM
jerzey908
11
Apr 1, 2010 03:16 PM
falcongsr
Honda Motorcycles
May 30, 2004 01:18 PM
Type R 01
Feb 12, 2003 04:35 AM
