Transmission problem
Old Feb 11, 2003 | 08:09 PM
Type R 01's Avatar
Default Transmission problem
Is there a difference between gear box and transmission oil or is it the same.
Old Feb 11, 2003 | 08:10 PM
Reid's Avatar
Global Moderator
Default Re: Transmission problem (Type R 01)
Use Honda MTF only.
Old Feb 11, 2003 | 08:11 PM
TeamTooQuick's Avatar
Default Re: Transmission problem (Reid)
Use Honda MTF only.
Thats what i use....
Old Feb 11, 2003 | 08:20 PM
migs's Avatar
Use Honda MTF only.
Old Feb 11, 2003 | 08:27 PM
Type R 01's Avatar
Default Re: Transmission problem (Migs)
Are they both together or seperate?
Old Feb 11, 2003 | 08:28 PM
migs's Avatar
Same, just different terminology.
Old Feb 11, 2003 | 08:29 PM
Type R 01's Avatar
The reason why im asking is because the transmission just blew in my 90 integra. it has 170k miles on it. I just had the transmission oil replaced and my mechanic said it had gear oil in there but is supposed to have motor oil. he replaced it with motor oil a week later the transmission blew there is a hole in it and all the oil leaked out. A friend told me that the transmission takes motoroil and the gear box takes gear oil. Is this true or are they both the same?
Old Feb 11, 2003 | 09:15 PM
01-1293's Avatar
the transmission takes MTF (Manual Transmission Fluid)....whoever said you should use motor oil is a complete retard
You tranny probably blew from using motor oil in it........
hahah.........gearbox is synonomous with transmission.........they are two different terms for the exact same thing
[Modified by 01-1293, 10:18 PM 2/11/2003]
Old Feb 12, 2003 | 03:06 AM
D's Avatar
D
Default Re: Transmission problem (01-1293)
please stop with the false information, retard. MTF and typical motor oil are very similar in composition, motor oil will be fine in a transmission. however, i would choose honda MTF over motor oil.
D
Old Feb 12, 2003 | 04:35 AM
Fuuma0083's Avatar
Default Re: Transmission problem (D)
Redline Tranny Fluid
petty$rep
26
Jun 29, 2024 10:21 AM
91grape
Transmission & Drivetrain
21
Jul 31, 2012 11:48 AM
jdm702
Apr 15, 2010 04:50 AM
Gsir8
Jan 22, 2007 07:13 PM
phyzJunkieCivic
Jul 31, 2006 04:15 PM
