TPS problem!!!! Throwing code 7, voltage is right but im confused. Please help!!!!
Old Dec 9, 2006 | 02:41 PM
h22civ's Avatar
Default TPS problem!!!! Throwing code 7, voltage is right but im confused. Please help!!!!
My friend and I just installed the Skunk 2 Pro Series manifold with a J G Edelbrock 65 MM throttle body on his OBD0 B16A . There is no problem until you give it full throttle, then it throws the code 7. When you just ease around no code is thrown. I am confused of the problem. Please someone help me out, any suggestion is greatly appreciated. Is there any thing else we overlooked that you could help me out with . Thanks
Huie
Old Dec 9, 2006 | 02:47 PM
Chiovnidca's Avatar
Default Re: TPS problem!!!! Throwing code 7, voltage is right but im confused. Please help!!!! (h22civ)
How much voltage at wot?
Old Dec 10, 2006 | 07:33 PM
h22civ's Avatar
Default Re: TPS problem!!!! Throwing code 7, voltage is right but im confused. Please help!!!! (Chiovnidca)
The voltage at closed throttle is .47 and WOT is 4.94. Thanks for your help!!
EG Hatch stock H22
13.01 at 104.12
Im dippin in the 12's next Sunday!!
Old Dec 10, 2006 | 08:32 PM
h22civ's Avatar
??????Any suggestions!!!!?????
Old Dec 11, 2006 | 05:30 PM
h22civ's Avatar
Old Dec 11, 2006 | 05:39 PM
92civicfreak's Avatar
that sounds about right... i would say try centering the tps... still a code, to the left then thr right... but b/4 that just make sure your connections are tight & notihngis cut into the wire... makre sure the wires aren't wet or by any heat
Old Dec 11, 2006 | 05:59 PM
mar778c's Avatar
Community Builder
Community Influencer
I thought TPS voltage should range from .5 to 4.5.
Old Dec 12, 2006 | 03:19 AM
Chiovnidca's Avatar
I thought about 4.5 should be the max.
Old Dec 12, 2006 | 07:30 AM
thesmogman's Avatar
Do you have the old one? if so connect it up and see what the voltages say on it.
Then match... 4.5 at wot and .5 idle is right.
Old Dec 12, 2006 | 07:56 AM
haroldthefly91crx's Avatar
Default Re: TPS problem!!!! Throwing code 7, voltage is right but im confused. Please help!!!! (thesmogman)
i had the same problem when i had to replace my tps, i just loosened it and adjusted it to the center as best i could and it fixed the problem
Old Dec 12, 2006 | 01:54 PM
if it goes past 5v u have aproblem cuz 5 volts is the reff
Pinarr
May 18, 2012 08:36 AM
Devious951
Sep 18, 2009 05:11 PM
xander1100
Aug 17, 2009 12:10 AM
rhdins
Jul 20, 2008 05:12 AM
RABBIT9
Jan 9, 2003 05:45 AM
