TPS Problem?
Old Jul 13, 2008 | 05:15 PM
rhdins's Avatar
Default TPS Problem?
I'm getting code 7, tps(throttle position sensor). I checked, and I'm getting 5 volts to the tps, and I checked all the wires and connections in the circuit and they look good. So then I check the voltage with the key on, and I'm getting .001v - 3.0v(closed to wide open).
My question is, will I get a code if it's not adjusted correctly, or if the initial voltage is too low? Or will it only give the code if the tps is bad? And am I getting those voltages because it isn't adjusted correctly, or has it gone bad? Thanks.
Old Jul 13, 2008 | 09:06 PM
rhdins's Avatar
Default Re: TPS Problem? (rhdins)
Does it give a code if the initial voltage is below 0.45v (closed voltage)? If so then I probably just need to adjust it.
Old Jul 15, 2008 | 08:51 AM
99accordFX's Avatar
U could try to replace it lol.
Old Jul 15, 2008 | 09:13 AM
HONCORD's Avatar
Did you temper with the TPS and then the Check Engine kicked on?
Even if you didnt, Accords are notorious for the code 7(tps) and also 43(O2). So you're not the only one with that problem. Replace it as others do, just like the new kid told you. Hope it fixes it.
Old Jul 15, 2008 | 11:19 PM
aasaa666's Avatar
its .49v closed, 4.5v at wide open throttle. you can give or take for the open reading but the closed one should be .47v to .49v.
Old Jul 20, 2008 | 05:12 AM
itsmejto's Avatar
lotsa guys install the tps incorrectly. The accuator arm has to engage into the slot in the throttle body arm and it does not do this on it's own, you need to check it with a meter when your done to see if it's sending a variable voltage after you installed it.
realmike15
Honda Civic (2001 - 2005)
Apr 17, 2011 06:07 PM
Devious951
Sep 18, 2009 05:11 PM
GSE980
Jun 4, 2006 01:15 AM
ALLshowNOgoLS
May 4, 2006 02:19 PM
kagegod
Aug 16, 2004 07:59 PM
