MSD 2step & Timing Retard
Old Dec 8, 2006 | 12:50 PM
Dunc's Avatar
BCICAN
Default MSD 2step & Timing Retard
I've been searching the last couple of days and found plenty on how to wire the 2step, but I have a question....
- Would it be beneficial or bad to wire the 2step <U>and</U> the timing retard wires to the same 12v source? Basically so that when the switch/button is pressed, it holds the rpms constant <U>while also</U> pulling 0-9.9* of timing out. I didn't know if people are doing this or if they are just using the 2step by itself. What's your input?? Thanks
Old Dec 8, 2006 | 04:22 PM
mrbsponge's Avatar
Default Re: MSD 2step & Timing Retard (AF-P Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">I've been searching the last couple of days and found plenty on how to wire the 2step, but I have a question....
- Would it be beneficial or bad to wire the 2step <U>and</U> the timing retard wires to the same 12v source? Basically so that when the switch/button is pressed, it holds the rpms constant <U>while also</U> pulling 0-9.9* of timing out. I didn't know if people are doing this or if they are just using the 2step by itself. What's your input?? Thanks </TD></TR></TABLE>
YES, thats what i do, i believe in order for the 2 step on the digital 6 to work, you HAVE to have the timing retard wire hooked up regardless, although i may be wrong. but you wont believe the amount of boost 9.9 degrees makes
Old Dec 8, 2006 | 06:06 PM
Pro-Am 1934's Avatar
Yes you can do that, but if it is a bigger turbo then the amount of timing it is capable of pulling out may not be enough to build the boost levels you are looking for. They are separate wires: blue for the two-step, and pink for the timing. They can be hooked up individually or together.
Jason
Old Dec 8, 2006 | 06:34 PM
Dunc's Avatar
BCICAN
Default Re: MSD 2step & Timing Retard (Pro-Am 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pro-Am 1934 &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can do that, but if it is a bigger turbo then the amount of timing it is capable of pulling out may not be enough to build the boost levels you are looking for. They are separate wires: blue for the two-step, and pink for the timing. They can be hooked up individually or together.
Jason</TD></TR></TABLE>
Yea I didn't know if it would build alot of boost, but I don't consider it to be a "big" turbo....more of a large medium haha. It's the T3 60-1, .82, stage 5 wheel.
I guess I'll just wire both the pink & blue to the horn button on the sparco steering wheel. Can't get much cleaner than that I would think. Thanks for the input guys
MassScene
Oct 17, 2006 07:53 PM
redpeppers
Jul 25, 2005 09:39 PM
thatbluecrx
Feb 27, 2005 10:15 AM
Tchleung
Jul 20, 2003 10:11 PM
BIG RICH
Jun 22, 2003 05:03 PM
