time for oil change...which oil filter?
Old Dec 6, 2006 | 04:08 PM
silentdeath12886's Avatar
Default time for oil change...which oil filter?
I ahve a dc4 ls with close to 98k on it. Which filter should i be looking at. i was reading that s2 filters are smaller and can create more oil pressure but does it fit on my b18b1? I searched and came up with a lot of different answers. last oil change i ran mobil1 oil filter. im looking for an oem filter that has good filtering capabilities, increased/stock oil pressure and good flow. as far ive read nippon, fram(canadian), hamp(jdm), filtech(usa) are all oem. as well as the s2. also read that toyo and filtech are the same. im currently leaning towards toyo's s2000 filter cause ive heard good things about it. is there a large or small size like hamp?
Old Dec 6, 2006 | 04:18 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: time for oil change...which oil filter? (silentdeath12886)
The S2K filter is bigger than an integra filter and it fits my b18c no problem. Just get whatever works for you.
Old Dec 6, 2006 | 04:34 PM
PrinceAli132's Avatar
I am planning on using a S2k, last time I went to Honda they were out, so I just got a civic one.
Ali
Old Dec 6, 2006 | 04:53 PM
Uncle Willie's Avatar
Default Re: time for oil change...which oil filter? (PrinceAli132)
I filters a filter IMO. I would just go with a purolater and mobil 1. The oil is what really matters.
Old Dec 6, 2006 | 05:00 PM
JmurGSR98's Avatar
What about PureOne filter?
Old Dec 6, 2006 | 05:04 PM
Default Re: time for oil change...which oil filter? (Uncle Willie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Willie &raquo;</TD></TR><TR><TD CLASS="quote">I filters a filter IMO.</TD></TR></TABLE>
Are you trying to say "a filter is a filter, IMO"
If so,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">the us-made oem filter is much better, it is made by filtech and has metal endcaps(which is a good thing). the ones made in canada are utter crap with their cardboard endcaps and made by fram(worse company on the planet). there are some stories out there that talk about how the cardboard endcaps can break apart and mix in with your oil, causing a decent amount of damage.
btw the design of the filtech filter offers higher oil pressure. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=628322
https://honda-tech.com/zerothread?id=776832
https://honda-tech.com/zerothread?id=692703
https://honda-tech.com/zerothread?id=645376
https://honda-tech.com/zerothread?id=257687
https://honda-tech.com/zerothread?id=667846
https://honda-tech.com/zerothread?id=301809
https://honda-tech.com/zerothre...84428
https://honda-tech.com/zerothread?id=749869
https://honda-tech.com/zerothread?id=338193
Ali
Old Dec 6, 2006 | 05:25 PM
i did my research on oil already and keeping it with mobil1 full synthetic 10w30 for summer and 5w30 for winter and maybe treating my motor every now and then with purple royal.
Old Dec 6, 2006 | 05:27 PM
stumpyf4's Avatar
I've switched to Nippon filters which I picked up at NAPA. Cut one open and it looks very nice; steel endcaps, filter material well pleated, filter material quality looks nice. I wouldn't hesitate at recommending them.
Old Dec 6, 2006 | 05:38 PM
mrinno's Avatar
Default Re: time for oil change...which oil filter? (stumpyf4)
i usually just use fram, since it seems like a well known brand, but i ALWAYS use mobile, except this one time, i tried the castrol gts shiit or whatever on my 3000gt, and it caused smoke to come out of my exhaust, flussed that shiit out, and replaced with mobile a few days later, and worked fine, so .. fram + Mobile oil
Old Dec 6, 2006 | 05:40 PM
Boots's Avatar
Default Re: (silentdeath12886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote"> maybe treating my motor every now and then with purple royal.</TD></TR></TABLE>
royal purple maybe?
Old Dec 6, 2006 | 05:41 PM
surprised not to see any voted for toyo roki since i heard they are also very good and correct me if im wrong but arent s2000 filters made by toyo roki.
Old Dec 6, 2006 | 05:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote">surprised not to see any voted for toyo roki since i heard they are also very good and correct me if im wrong but arent s2000 filters made by toyo roki.</TD></TR></TABLE>
If i remember correctly the S2K filters are made by toyo roki and i voted for the S2k.
Ali
Old Dec 6, 2006 | 06:19 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razor &raquo;</TD></TR><TR><TD CLASS="quote">the us-made oem filter is much better, it is made by filtech and has metal endcaps(which is a good thing). the ones made in canada are utter crap with their cardboard endcaps and made by fram(worse company on the planet). there are some stories out there that talk about how the cardboard endcaps can break apart and mix in with your oil, causing a decent amount of damage.
btw the design of the filtech filter offers higher oil pressure.</TD></TR></TABLE>
If this is true then you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrinno &raquo;</TD></TR><TR><TD CLASS="quote">i usually just use fram, since it seems like a well known brand, but i ALWAYS use mobile, except this one time, i tried the castrol gts shiit or whatever on my 3000gt, and it caused smoke to come out of my exhaust, flussed that shiit out, and replaced with mobile a few days later, and worked fine, so .. fram + Mobile oil </TD></TR></TABLE>
Might want to switch to something else.
I didn't know about this but I will no longer be using Fram in my wife's car or in my truck. But for my GSR I use OEM honda S2K
Old Dec 6, 2006 | 07:45 PM
Deluzional's Avatar
Default Re: (SlammedDC2)
pureone purilator
Old Dec 6, 2006 | 08:04 PM
vladd's Avatar
http://www.ntpog.org/reviews/filters/filters.shtml read this
Old Dec 6, 2006 | 10:14 PM
Blk-dc2's Avatar
Default Re: time for oil change...which oil filter? (civicdxtyper)
i heard the oem honda filter gives you better oil preasure...
fram sucks, thats just me
Old Dec 6, 2006 | 10:15 PM
IntegraDOHCter's Avatar
I used to run the Amsoil filter..with amsoil syntehtic..was paying out the cornhole for it too.
Now I run K&N oil filt + Royal Purple synth I love it..
Old Dec 6, 2006 | 10:19 PM
Blk-dc2's Avatar
Default Re: time for oil change...which oil filter? (BLACK-dc2)
what about the mugen filter are they any good????? cost alot....
i was thinking about using one
Old Dec 6, 2006 | 11:22 PM
__oversea's Avatar
OEM or NAPA gold
Old Dec 6, 2006 | 11:50 PM
1997 gsr's Avatar
i would go with a s2k filter and royal puple oil
Old Dec 7, 2006 | 07:38 AM
Sam92Teg's Avatar
Default Re: time for oil change...which oil filter? (mrinno)
Was that Mobil oil conventional or synthetic?
I have over 300K miles and counting using Castrol GTX and Pure One oil filters. I don't need any more proof of their quality than my real world experience. When I pull the valve cover, the head is clean as a whistle. I still get 340 miles to the tank averaging 32 mpg with city/hwy mixed driving. Maybe I will rebuild the engine at 350K miles whether it needs it or not, lol, because I have cams and pistons just begging to go in.
Old Dec 7, 2006 | 08:52 AM
mrinno's Avatar
Default Re: time for oil change...which oil filter? (Sam92Teg)
Oh, im not sure was it the conventional or synthetic, i use Mobile1, the one that cost like 5-6 bucks a liter ..
and i was before, in my 3000gt, i used the Castro GTX high Mileage one, the green bottle, with a Fram filter, and that caused my car to produce some white smoke from the exhaust, i changed it to mobile, and no more smoke. so yeah ..
is people saying the Honda or Napa filters are better ??
Old Dec 7, 2006 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrinno &raquo;</TD></TR><TR><TD CLASS="quote">Oh, im not sure was it the conventional or synthetic, i use Mobile1, the one that cost like 5-6 bucks a liter .. </TD></TR></TABLE>
sounds like synthetic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrinno &raquo;</TD></TR><TR><TD CLASS="quote">is people saying the Honda or Napa filters are better ??</TD></TR></TABLE>
Certain honda filters are better. Read the links i posted.
Ali
Old Dec 7, 2006 | 09:06 AM
mrinno's Avatar
I SEE THANKS, so how would i come on getting that 15400-P0H-305 filter, since the person said honda discontinued making them, do i go to the Honda dealer or a retailer, and how much would they usually cost?
Old Dec 7, 2006 | 09:10 AM
You probably still are getting some, because many dealerships still have them on the racks. Honda dealer is fine. As for how much they cost, i don't remember off the top of my head. You could probably look at prices online for those dealerships that have their parts department online, or go to a few local dealerships. I remember going to my closest honda dealership and they wanted like 4 bucks more than the other dealership.
Ali
