Shifter into em1
Old Dec 5, 2006 | 12:31 AM
dohcteg's Avatar
Default Shifter into em1
Hi guys. Just wondering will a GSR or TYPE R integras shifter direct fit into my 2000 EM1? Whats the difference between type r/gsr/LS shifter? WHich one is best in my car? Thanks!
Old Dec 5, 2006 | 10:16 AM
dohcteg's Avatar
Default Re: Shifter into em1 (dohcteg)
Wow... no one can answer that?
Old Dec 5, 2006 | 10:49 AM
BlueIntegraBoy's Avatar
Yes, an Integra shifter will work. The Integra is dual bend, while the Civic is single bend.
All Integras are the same, except that 00-01 ITR are not black.
Old Dec 5, 2006 | 06:16 PM
dohcteg's Avatar
Default Re: Shifter into em1 (BlueIntegraBoy)
Thanks for the info . I was thinking of getting skunk2 ss but i heard it kills your synchro! Tried to search all over h-t for info but no luck.
When i put in the gsr shifter will it be the same as putting in the short shifter or will it be the same as stock. I rather not get a SS if it kills my tranny.
Old Dec 5, 2006 | 06:51 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info . I was thinking of getting skunk2 ss but i heard it kills your synchro! Tried to search all over h-t for info but no luck.
When i put in the gsr shifter will it be the same as putting in the short shifter or will it be the same as stock. I rather not get a SS if it kills my tranny.</TD></TR></TABLE>
It kills your syncros if trips to the supermarket become fast and the furious. Usually syncros (and the reason you were told it'll go out) is b/c u slam it into gear b4 the clutch is fully engaged (or disengaged - point being, still partially connected).
Old Dec 5, 2006 | 07:18 PM
pdiggitydogg's Avatar
it wont hurt your synchros as long as youre not throwing the lever like a jackass...shift normally and theyre fine
Old Dec 5, 2006 | 07:44 PM
doood's Avatar
been there done that
Default Re: (pdiggitydogg)
short shifters dont kill syncro's. dumbass drivers kill syncros. and a teg shifter isnt going to shorten the throws anymore than your stock one.
Old Dec 5, 2006 | 08:30 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg &raquo;</TD></TR><TR><TD CLASS="quote">I rather not get a SS if it kills my tranny.</TD></TR></TABLE>
Short shifters don't kill transmissions... idiots do.
Old Dec 5, 2006 | 08:31 PM
Blk00EJ8's Avatar
Default Re: (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">short shifters dont kill syncro's. dumbass drivers kill syncros. and a teg shifter isnt going to shorten the throws anymore than your stock one.</TD></TR></TABLE>
Damn, beat me to it by a whole 46 minutes.
Old Dec 5, 2006 | 08:42 PM
TRAP_STAR's Avatar
Default Re: Shifter into em1 (EKcivicEX)
^^ cant agree more
Old Dec 5, 2006 | 10:27 PM
Loi-Tech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys. Just wondering will a GSR or TYPE R integras shifter direct fit into my 2000 EM1? Whats the difference between type r/gsr/LS shifter? WHich one is best in my car? Thanks!</TD></TR></TABLE>
you will haft to cut the integra shifter width a bit shorter for it to fit into the linkage. the integra shifter width is thicker then the civic si shifter.
Old Dec 5, 2006 | 10:32 PM
Loi-Tech's Avatar
^^ the botton part where it bolts to the linkage itself will be wider on the integra shifter.
Old Dec 5, 2006 | 10:46 PM
dohcteg's Avatar
Default Re: (Loi-Tech)
Thanks for all the infos guys. Idiot drivers kill synchros not the SS got it. I'll go ahead and buy the DC shifter and install it. Ill post up pix when im done should be in 1 or 2 days
Old Dec 5, 2006 | 11:35 PM
Loi-Tech's Avatar
Default Re: (dohcteg)
glad to help
wizeguy1
Apr 13, 2007 05:57 PM
ill3galdr1v3r
18
Oct 12, 2005 08:44 PM
ill3galdr1v3r
Oct 12, 2005 12:41 PM
ieatrice
Aug 1, 2004 09:04 PM
iam94wcyy
Jul 13, 2004 07:53 AM
