shifter height
i was wondering if there is a shifter out there is essentially the same as the stock integra shifter, but about 1-2 inches shorter, same throw, just shorter height.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam94wcyy »</TD></TR><TR><TD CLASS="quote">i was wondering if there is a shifter out there is essentially the same as the stock integra shifter, but about 1-2 inches shorter, same throw, just shorter height.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg »</TD></TR><TR><TD CLASS="quote">i've found the gsr shifter to be the smoothest. aftermarket shifters grind to much</TD></TR></TABLE>
I have yet to have a grind due to my short throw shifter after 2 years of use.
thanks </TD></TR></TABLE>
If all you want is a shifter that is shorter in height, and the length of the throw doesn't matter to you, then just cut and rethread a stock shifter.
Grinding is due either to worn transmission components, possibly clutch problems, or more usually driver error. A short-throw shifter does NOT cause a transmission to grind.
BLUE EH3
62
Nov 4, 2007 03:16 PM
EGhatch33
10
Apr 27, 2006 10:03 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
