tw sensor
Old May 9, 2002 | 10:09 PM
Unsung's Avatar
Default tw sensor
Ok my friend's tw sensor (engine coolant sensor) is triping the engine light and going out about every two months he drives a '94 Accord ex, he has no leads as to what could be causing it, and I was wondering if anyone had any suggestions, that would be great, any advice is helpfull thanks
[Modified by JDM B Series, 7:12 AM 5/10/2002]
Old May 10, 2002 | 11:52 AM
Perfectionist's Avatar
Default Re: tw sensor (JDM B Series)
If the wiring and connections are good, the TW sensor itself could be bad. They do have a tendency to go 'open' at times. FYI, they are just variable resistors that change with temperature. If you had the time and patience, you could attach an ohm meter to it and heat up the sensor and let it cool while watching the meter. A new one is about $30 if I recall correctly.
2009HondaAccord
Feb 18, 2018 06:41 PM
DC_Legacy
Jun 3, 2008 06:13 AM
JDM Accord
Aug 26, 2002 01:28 PM
