door question
Old Dec 1, 2006 | 12:34 PM
MugenManR's Avatar
Default door question
the part were your arm rest and and were the window buttons are, can that come out to replace with other ones if so are there any diy or write ups thanks ??
Old Dec 1, 2006 | 12:44 PM
DC_RaceR's Avatar
Default Re: door question (MugenManR)
Are you talking about the door panel?
You just pop right out.. slide up and replace R/R.
Old Dec 1, 2006 | 01:06 PM
MugenManR's Avatar
that hole peice were the carpt part is on your door panel. dose that come out so i can for instances put the ctr red, or the sir colored ones in.
Old Dec 1, 2006 | 01:12 PM
jdmyoo's Avatar
i belive so. i have seen people change them not 100% sure how tho..
if u take ur door card off and look. there should be some plastic welds. cut em or melt them. and should come off. i soppse puttin bk on will be a bit trickyer. but you could weld it or even put some self tapper screw in..
sorry mate if it aint much help.
but it can be done
what car is it
Old Dec 1, 2006 | 01:19 PM
MugenManR's Avatar
Default Re: door question (jdmyoo)
my 98 ek, im switchin it to the sir, and i go the hole interior. but thre black pannels and i cant get a black dash. so ima jsut keep it grey and swtich the armrests.
Old Dec 1, 2006 | 01:21 PM
jdmyoo's Avatar
lol
good luck
Old Dec 1, 2006 | 01:29 PM
MugenManR's Avatar
is there any possible way i can get a lhd black dash
Old Dec 1, 2006 | 01:33 PM
jdmyoo's Avatar
not too sure.
if u can find 1 then it will fit.
but appat from that no
jst paint it......joke
Old Dec 1, 2006 | 01:43 PM
MugenManR's Avatar
i always run into prolbems when i wana do ****, god damn hondas.
Old Dec 1, 2006 | 02:12 PM
93egsir's Avatar
I made my door panels blue to match my seats.
You need to unistall the door panel and lay it face down.
on the back you will see little plastic circles that have been melted almost flat to hold the arm rest panel on.
I used a hollow drill bit like for drilling through rubber to "cut" these melted spots.
to reattach the panel after recovering it I used #10 pan head screws and fender washers.
on the far side of the picture you can see the recovered panel I also put 3 way jl speakers in and shaved the window crank down and installed pwr windows to make the panel a little more flush
Old Dec 1, 2006 | 08:27 PM
MugenManR's Avatar
Default Re: door question (93egsir)
that was huge help. thanks alot
specoperformance
Sep 15, 2008 06:56 PM
eL
Audio / Security / Video
18
Dec 19, 2007 02:15 AM
baconcrx
Welding / Fabrication
Apr 28, 2006 08:55 AM
neo1z
Jul 6, 2002 12:33 PM
