VTEC only pulls to 6400!!
Well recently i did a mini me swap (d16z6 head on a d15b7 block........p28 ecu, new dizzy, new spark plugs and spark plug wires) my vtec engages at around 5000 rpm's (you can def here it kick in) but it only pulls to about 6400 rpms then it starts to really struggle........i checked my oil level and it is fine.......but i did see alittle sludge on the stick (im gonna change the oil again) do you think that could be the problem?? im yet to clean or look at the vtec solenoid.........im just curious if anyone else has had this problem and what did they do to fix it...........thanks
p28's rev limiter is something like 7400rpm could be a tad more or less. But a d16z6's red line is at 7200rpms. Not sure why your motor isn't pulling past 6400. Anyway are you throwing any CEL's?
by "not pulling" is it not revving past 6400 or it just doesn't seem to make much power past 6400... which might be the case because there's usually a difference between where it makes peak power and the rev limit.
im almost postive vtec is engaging (you can hear it with my loud *** intake)
i checked my timing and its dead on
it goes past 6400..........but after about 6500 the motor just falls flat on its ***.........i thought the peak power on a d16 is around 6800
i understand the SOHC VTEC isnt all that great.......but from reading some of the threads it seems like everyone who did a mini me the vtec pulled to 7200
is there a way to check if the tach is inaccurate?
Well i did use new oil when i did the swap.....but when i checked it the other day i did notice alittle sludge on the dipstick.........so im gonna change it tomorrow and see if that helps at all
94EJ1CivciSi
Oct 19, 2010 10:14 AM
Ge-money
17
Sep 6, 2006 08:45 AM
