WHY does my car burn so much oil!??!?!
Old Nov 30, 2006 | 06:38 PM
turboeg831's Avatar
Default WHY does my car burn so much oil!??!?!
My car burns oil like a motherf*****!!! i have to change the oil every 1000 miles or so...and there's black smoke coming out of my muffler when i run it hard...anyone have any ideas?
My setup AKA poor mans type r:
pr3 head w/ JDM B-Series Valve Cover
94' b18c1 block
00' b16a2 tranny
Skunk2 Cam Gears
Skunk2 Intake Manifold
3'' Intake w/ AEM cone filter
B&M Fuel Pressure Regulator
Stage 1 Exedy Clutch
Type R Injectors
Type R Flywheel
Type R Fuel pump
Type R Oil pump
CTR Crank Pulley
Unknown strut bar
Energy Suspension mount inserts
BRAND NEW NGK Iridium Sparks w/ new NGK Wires
DC Sports 4-1 Header
Magnaflow Hiflow Cat
3'' Apex'i N1 catback
Old Nov 30, 2006 | 06:42 PM
flatblack-h22's Avatar
Default Re: WHY does my car burn so much oil!??!?! (turboeg831)
running rich, to much fuel maybe. got a cat on the car? if you have a straight pipe the excess gas thats not being burnt. try changing the fuel filter
Old Nov 30, 2006 | 06:44 PM
turboeg831's Avatar
eh...you needa help me out mr.EGg. come fix my car, and bring the my lip too.
Old Nov 30, 2006 | 06:51 PM
Kafelatte's Avatar
i don't think running rich cause it to burn oil. might be a bad psiton ring or valve seal.
Old Nov 30, 2006 | 06:58 PM
Default Re: WHY does my car burn so much oil!??!?! (kay20adc2)
crack ringlands? hmm maybe.
compression test
Old Nov 30, 2006 | 07:24 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg831 &raquo;</TD></TR><TR><TD CLASS="quote">My car burns oil like a motherf*****!!! i have to change the oil every 1000 miles or so...and there's black smoke coming out of my muffler when i run it hard...anyone have any ideas?
94' b18c1 block
00' b16a2 tranny
Skunk2 Cam Gears
Type R Injectors
Type R Flywheel
Type R Fuel pump
Type R Oil pump
CTR Crank Pulley
Unknown strut bar
3'' Apex'i N1 catback</TD></TR></TABLE>
JDM needs more oil, sorry.
Compression, leakdown, answer.
Old Nov 30, 2006 | 07:27 PM
yeahme17's Avatar
unless the head is cracked which unless a moron was torqing it down it shouldn't be and or it was super over heated i would say the rings are shot. try doing a compression test should find out which cylinder is leting oil in real quick if it burning it that bad.
Old Nov 30, 2006 | 08:35 PM
.I.Need.Money.'s Avatar
If your compression is good, then I'd say it's your oil-control rings.
Search it up dude, there's an assload of info on it. I have the same problem.
zach53
Feb 28, 2012 03:05 PM
JDMb18c1HATCH
32
Aug 5, 2010 08:59 PM
turboeg831
22
Dec 1, 2006 06:23 AM
1991civicsi
Feb 6, 2006 04:04 PM
smeister
Oct 1, 2002 03:22 AM
