poor mans type r
Old Nov 27, 2006 | 06:58 AM
CeeJayy's Avatar
Default poor mans type r
what kind of power can you expect from it? for example no mods just stock b18c1 block and stock b16a2 head?
Old Nov 27, 2006 | 07:06 AM
SE3Pimp's Avatar
Default Re: poor mans type r (CeeJay16)
stock gsr numbers.. lol
Old Nov 27, 2006 | 08:15 AM
Padawan's Avatar
Darth ModerVader
Default Re: poor mans type r (EndlessDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EndlessDc2 &raquo;</TD></TR><TR><TD CLASS="quote">stock gsr numbers.. lol</TD></TR></TABLE>
Basically, yes. I've never really understood the fascination with the "poor man's Type-R", but I suppose the term appeals to some people.
Old Nov 27, 2006 | 08:18 AM
H9Omega's Avatar
The fascination of a poormans r is basically what it's named. I doubt someone with a GSR already will slap on a b16 head. It is the other way around. Maybe someone with a b16 head and wanting to get something stronger and more powerful by purchasing a shortblock and mating it with the head. If you really intend on making a poor mans r, atleast change the gsr pistons because it will lower your CR due to the b16 head.While your at it get some type r cams or s2s2's with a nice lsd and it should put some decent power, slightly more than a GSR or so i've seen.
Old Nov 27, 2006 | 08:48 AM
SE3Pimp's Avatar
Default Re: (H9Omega)
most people do poor mans R because they are piecing together a setup, usually if someone buys a gsr bottom and gets a good deal on a b16 head. Its pretty pointless if you already have a gizzer head. Just change out the gsr cams and stock intake manifold and you got a nice setup to run with.
Old Nov 27, 2006 | 08:54 AM
AntiStock's Avatar
That is the motor setup that I currently have in my 97 HX...I bought it that way.
It makes decent power, but nothing to write home about. I'd say maybe in the 160whp range?
Old Nov 27, 2006 | 09:37 AM
one slow coupe's Avatar
i kinda have a poor mans itr..kinda
ls block
b16 pistons
b16 head
itr cams springs retainers
aebs IM
tuned
b16 trans
went 13.87 on radials in my coupe
Old Nov 27, 2006 | 10:02 AM
lowsiciv's Avatar
if you want a little more compression get the head lilled a little and put it a nice head gasket itll help make a little more power. im doing the poor mans type r build but im building the motor hopefuly to 200 whp.
dsmh8tr
Jun 10, 2008 03:46 AM
ironiceghatch
Jan 26, 2007 08:02 AM
b20_driven
Oct 14, 2006 04:38 AM
94whitegsi
Sep 25, 2006 01:54 PM
rock~1
29
Jun 21, 2006 07:53 AM
