h22a swap (having vtec issues)
Old Nov 22, 2006 | 12:55 PM
h22silvia's Avatar
Default h22a swap (having vtec issues)
i swap my civic ex and my vtec was working fine 1st and 2nd day after that it doesnt work any more.its sputters once it engages vtec after 5000 rpm. check the oil,gota new silenoid,also check the wiring everything was fine.so we tried to check pressure in the head it goes to 60 psi and then ones it hits 4500 rpm it drops back down........ it seems like its not getting enough oil. i check the oil pick up and cleaned it. we check the compression its 200,190,190,200. so we know theres nothing wrong with the motor. PLEASE someone help me figure this out. i havent been driving since then. i also change the oil and put sythetic
Old Nov 22, 2006 | 08:00 PM
dc2vu's Avatar
Check connections to the ECU. Pull the plugs out and put em back in. A lot of cars seem to he having that problem around me.
Old Nov 23, 2006 | 05:42 PM
Turbogixxer's Avatar
Default Re: h22a swap (h22silvia)
Run a light from teh Vtec solenoid and drive teh car and hit vtec. See if it is actually giving the solenoid power.
Old Nov 23, 2006 | 05:44 PM
fastwanabe's Avatar
Default Re: h22a swap (Turbogixxer)
What ECU u running? Have u tried a different ECU?
Old Nov 25, 2006 | 11:10 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread?id=1812135
ari integra
Feb 1, 2012 03:59 AM
h22silvia
Nov 9, 2006 07:59 AM
tuckin15s_8315
Sep 28, 2005 10:12 PM
veilsides2000
Nov 27, 2004 11:18 PM
94minimesleeper96
Apr 8, 2004 08:56 AM
