2000 EX b16b swap
Swap came with the ctr oem harness. Besides extending plugs to oppisite sides of the bay to compensate for RHD, will any other issues arrise.
99-00 CTR harness with 99-00 ecu?
why would you use the JDM Harness?
The stock civic harness will plug in except for maybe the alternator plug, IAT, and maybe one or two other things. No point in extending half of your harness, screwing it up and causing headaches. Drop that sucker in just like any other b16. See if the ecu plugs into your harness, it should and if it doesn't then just run a chipped ecu
Stock harness is hacked beyond belief.
Why could you no plug in the CTR harness. 2 engine harness's plug into the ecu and the body connector plugs right in.
Any other issues will arrise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">What side is the steering wheel on in a JDM vehicle? So what side is the ECU on? Hence, the wiring harness is backwards. </TD></TR></TABLE>
WTF ?
WTF ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostonjuice »</TD></TR><TR><TD CLASS="quote">USE THE STOCK HARNESS!!!</TD></TR></TABLE>
agreed, or get your hands on a 99 si harness if you can... or even another stock harness... good luck...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 »</TD></TR><TR><TD CLASS="quote">yup, when i did mine i just bought a si harness</TD></TR></TABLE>
i did the same
i did the same
I ended up just pulling the harness off the clips behind the intake manifold and Turned the ecu connector side facing up vs. down.
Plugged in and runs perfext no CELs whatsoever.
I ended up using the CTR harness so i didnt have a bunch of left over plugs( vtec press., CKP, Evaporative canister, etc.)
nello a.
Dec 24, 2008 12:20 AM
june
Nov 30, 2001 06:49 PM
