D16Z6 coolant drain problem - help me
Old Nov 21, 2006 | 05:00 AM
EK45VTi's Avatar
Default D16Z6 coolant drain problem - help me
Hi...
Yesterday I wanted to change coolant on my newly bought D16Z6..
I unscrrew the radiator drain plug and only about 2 qt of coolant came out of the radiator... and that's odd because the system was full... so I poored the distilled water in and it only took 2 qt...
So I guess I DIDN'T COMPLETELY DRAIN the coolant...
So today I'm going to do it again properly and I was wondering if anyone knows WHERE IS THE BLOCK DRAIN BOLT ON D16Z6... I searched but found nothing...
Is it on the back of the engine near to the oil filter like on D16Y7 engine or is it placed somewhere else???
Please help me cos in about 2 hours I'm going to the garage so it would be great if I get an answer before I start...
Old Nov 21, 2006 | 07:57 AM
ykracing's Avatar
Default Re: D16Z6 coolant drain problem - help me (KKVTi)
front of block, below the exhaust manifold flange on the tranny side.
big (maybe 19mm) bolt with integrated washer.
Old Nov 21, 2006 | 12:51 PM
EK45VTi's Avatar
Default Re: D16Z6 coolant drain problem - help me (ykracing)
Thank you... I found it...
This time, almost 4qt of fluid drained from the system
Drained the system, flushed the radiator and block and everything is like it should be now...
MattsLegit
10
May 12, 2016 05:52 PM
Outrun
Sep 4, 2008 05:45 PM
return_2020
14
Oct 19, 2005 09:23 PM
nikkon
Mar 22, 2005 10:08 AM
frostcivic
43
Jul 15, 2004 01:47 PM
