D16Z6 coolant leak
D16Z6 coolant leak
My car overheated to Vegas again. It overheated in June during a previous Vegas trip and I ended up replacing a bypass hose that had split and was spraying coolant all over the place. I thought my problem was solved but now I see coolant leaking in the front of the engine just behind the exhaust manifold maybe 3 inches or so below the exhaust ports. I tried looking over the Helms .pdf but that thing is kind hard to navigate without knowing the page numbers.
Seagull Management
Re: D16Z6 coolant leak (Outrun)
Its leaking around the frost plug, see if its loose, if it is tighten it, might also be a good idea to replace the crush washer while your at it too, I've never seen a frost plug back out of a honda. I'd be concerned about that.
Re: D16Z6 coolant leak (94EG8)
Thanks. I've been so tired from Vegas that I was too lazy to prop the car up to look at it. My friend found a diagram of it too.
MattsLegit
10
05-12-2016 05:52 PM
EK45VTi
11-21-2006 12:51 PM
xavior66
11
01-21-2004 01:27 PM
