what could my problem by **video clip**
Old Nov 19, 2006 | 12:18 PM
black_bb1's Avatar
Default what could my problem be ??? **video clip**
So for the last 6 months I've totally neglected my car, like an idiot, and as I was driving home last night it started making a sound at first i thought that i had run over a box and it was draging from my undercarriage, but then it turned into a rumbeling sound, and when i got home it was like it is in the video. So I checked my oil and guess what there was next to none in there.
It sounds like something is in the head being churned and grinded around : (
any clue as to what it might be?
Video:
http://www.youtube.com/watch?v=psTxWpyE0qw
Old Nov 19, 2006 | 12:32 PM
bad-monkey's Avatar
video didn't work for me, however, it sounds like a bearing of some sort.
no oil is bad, but how did u check the oil level? because you can be down 2 qts and real low on the dipstick, and there'll still be enough to prevent you ******* up your engine. but if you drained it and there wasn't much left...did an oil light come on?
Old Nov 19, 2006 | 04:40 PM
f22b_dohc's Avatar
it sounds like a rod bearing
Old Nov 19, 2006 | 07:49 PM
roller3804's Avatar
take off the valve cover and see if you can see anything wrong. Did you feel a loss in power when you noticed the noise?
Old Nov 19, 2006 | 08:14 PM
AndyD's Avatar
Default Re: what could my problem be ??? **video clip** (black_bb1)
Low oil probably resulted in a spun bearing (crank or rod bearing).
I would start looking for a replacement engine, or a rebuild.
I better check my oil too. I have been meaning to, but haven't.
Good luck.
Old Nov 19, 2006 | 09:11 PM
black_bb1's Avatar
I didnt notice a loss in power, and havn't drained the oil yet, been @ work all day. I took off the valve cover and everything looks in place. I was driving normally when it hapened maybe hit 4k rpm tops on the way home. Also I forgot to add that when I got home it kind of smelled like burnt oil.
thanks for all the suggestions so far
Old Nov 20, 2006 | 04:26 AM
Apex1972's Avatar
That sounds like something under the timing cover. When my auto tensioner started going bad, it kinda sounded like that. I would not run it again until checking it.
Old Nov 20, 2006 | 07:54 AM
mkinpwrat12g's's Avatar
Default Re: what could my problem be ??? **video clip** (Apex1972)
im pretty sure you spun a bearing which isnt that uncommon for a h22. good luck, maybe you should drop your oil pan and see if you can see anything.
Old Nov 20, 2006 | 11:07 AM
black_bb1's Avatar
Default Re: what could my problem be ??? **video clip** (mkinpwrat12g's)
If it was a crank or rod bearing would my head still be ok? or would i need an entire replacement engine not just the shortblock?
Old Nov 20, 2006 | 12:38 PM
JDMhondalude22's Avatar
nope, you will be able to get a shortblock. IF it is your head for a really od reason, let me know, i have a spare h22a with a bent rod. the head is super super clean, pics upon request. but sounds to me like rod bearing. good luck.
Old Nov 20, 2006 | 01:30 PM
veetak's Avatar
That's exactally what my h23 sounded like when I spun a bearing.
Kangolbrand
Nov 29, 2006 01:25 PM
jdmintegralsvtec
Jun 23, 2006 12:29 AM
Boost Lee
Apr 23, 2005 05:07 AM
1.8
22
Jan 29, 2005 07:25 PM
firstgenrex
15
Sep 28, 2003 05:12 PM
