taking pin out of shift linkage??
Old Nov 17, 2006 | 08:55 AM
memorybox's Avatar
Default taking pin out of shift linkage??
I am under the car hammering anything on that pin i can get at it, and its not budging. how do i get that pin out of the shift linkage? its on a b18b1 swapped eg
Old Nov 17, 2006 | 09:05 AM
FIGARILA's Avatar
Default Re: taking pin out of shift linkage?? (memorybox)
they have a special punch for spring pins, i've never used but maybe that would help. I always use a small sledge hammer and plenty of swing room. Tryheating it up...
Old Nov 17, 2006 | 09:17 AM
CompressionFed's Avatar
Default Re: taking pin out of shift linkage?? (Heron of Alexandria)
a punch works best, many times you just need to hit it for a while. Once it starts to move its a sinch.
Old Nov 17, 2006 | 10:00 AM
NJcoupe's Avatar
Default Re: taking pin out of shift linkage?? (CompressionFed)
HONDA/ACURA LINKAGE PIN TOOL
• This unique tool allows the technician to accurately remove and install the shift linkage pin on vehicles using shift rod linkage.
• The custom features to this tool include a knurled handle for good grip, and a "guide step" at the end of the tool for precision removal and installation of the shift linkage pin.
• Made from heat treated steel the MST6455 insures a quick and painless process.
• Models: Honda: CRX 1984-1991 Civic 1986-2002 Acura: Integra 1987-2001
Part#: MST6455 Price: $21.80
Matco tools
Old Nov 17, 2006 | 10:48 AM
Bense's Avatar
hell yeah
Old Nov 17, 2006 | 10:54 AM
b18bturbo's Avatar
Default Re: (Bense)
if you in quick bind yuo can always use the long bolt on the starter just remove the long skinny one on the starter and use that it works every time in bind if you cant get ahold of the tool
Old Nov 17, 2006 | 11:19 AM
91SiZ6's Avatar
8mm punch or bolt and a hammer.
Old Nov 17, 2006 | 02:08 PM
APEX CRX's Avatar
Default Re: (91SiZ6)
if the roll punch doesn't work pull the whole linkage out.
Old Nov 17, 2006 | 03:29 PM
memorybox's Avatar
yeah i just unbolted the linkage from under the shifter and took the motor out
Old Nov 17, 2006 | 03:56 PM
Evil_1's Avatar
I've puched it out with an allen wrench before, you just got to find the right size.
Old Nov 17, 2006 | 06:33 PM
zccr-xsi's Avatar
Default Re: taking pin out of shift linkage?? (dxcoupe.)
[QUOTE=dxcoupe.]
hell yea i need one of them.i use a 4mm punch with some exteions works every time.
Old Nov 17, 2006 | 09:21 PM
Danny_EJ's Avatar
i use a phillips head stubby screw driver and a small hammer 2 good whacks and its free
Old Nov 17, 2006 | 10:27 PM
VRD^don's Avatar
Default Re: (Danny_EJ)
find a punch, bolt or something the same size as the pin and start pounding away with a 3lb mini sledge hammer..
Old Nov 18, 2006 | 01:02 PM
clayne's Avatar
Default Re: (k_motor)
Just pull that part of the linkage with the engine. Don't bother wasting time hammering under the car.
Otherwise goes to sears and pick up an 8mm "bitch-pin" punch.
Old Nov 20, 2006 | 06:26 PM
boostedbigguy's Avatar
Default Re: (Bense)
i just used a bolt that i grinded down to fit in the hold then a little step to seat on the edge of the pin and it works great every time, i used it to get out like 6 pins and is a sinch everytime
Old Nov 20, 2006 | 07:59 PM
khoalie's Avatar
Default Re: (boostedbigguy)
i don't know if you guys have air, but i use one of these, comes out in literally no time.
Old Nov 21, 2006 | 08:30 AM
b18sihatch's Avatar
part to actually do the job
Old Nov 21, 2006 | 10:45 AM
TwoRedEGgs's Avatar
Default Re: taking pin out of shift linkage?? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khoalie &raquo;</TD></TR><TR><TD CLASS="quote">i don't know if you guys have air, but i use one of these, comes out in literally no time.
One or two squeeeezzzes on the trigger usually work for us !! Some of them can be really stuburn and you have to be patient, make sure you dont get angry and beat on it super hard !!
Old Nov 21, 2006 | 03:08 PM
NJcoupe's Avatar
Default Re: taking pin out of shift linkage?? (TwoRedEGgs)
ACURA/HONDA AIR HAMR LINK TOOL
• Use an air hammer for quick service of shift pin.
• Includes a "guide step" for precise R&R of shift linkage pin.
• Made from heat treated steel for durability.
• Works on: HONDA Civic 1986-2002, CRX 1984-1991 ACURA Integra 1987-2001
Part#: MST6565 Price: $24.95
Old Nov 22, 2006 | 08:24 AM
itrSteez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">ACURA/HONDA AIR HAMR LINK TOOL
****, I wish I would have known about this years ago.
Old Nov 22, 2006 | 10:51 AM
d16dcoe45's Avatar
Default Re: taking pin out of shift linkage?? (itrSteez)
that air hammer OEM style tool is it....
vtecc
Jun 1, 2015 10:53 PM
user7889
Sep 28, 2008 03:27 PM
kornerk12
Mar 15, 2007 05:26 PM
MR. MIYAGI
Mar 12, 2004 12:34 PM
