Engine Harness???? Which one???
Old Nov 15, 2006 | 11:45 AM
misternguyen's Avatar
Default Engine Harness???? Which one???
Hey I have a 95 cx honda civic hatchback with a 97 obd2 gsr engine in it. My car right now runs but the VTEC does not kick in right??? I'm thinking that the wiring could be wrong. I was just going to switch up the wiring harnesses. Which one should I use??? OBD2 TO OBD1 or should I just stick with the regular factory one??? I have a p72 obd1 ecu right now. Really need some help to get my car running right. ANYONE??
Old Nov 15, 2006 | 12:02 PM
Furyof4's Avatar
Default Re: Engine Harness???? Which one??? (misternguyen)
http://technet.ff-squad.com/hybrid.92-95.obd2.htm
Just did the same swap recently and worked perfect using that ^ writeup. You'll have to add wires from the ecu to the engine harness for vtec, iab's, knock etc but that guide will get you close.
civicb18c1swap
Engine Management and Tuning
Jun 27, 2010 04:56 PM
cnydc2
Jul 14, 2009 07:14 PM
misternguyen
Nov 16, 2006 12:39 PM
misternguyen
Nov 15, 2006 07:37 PM
HB-Civic500
Oct 28, 2006 09:02 PM
