98' CX brake problems
Old Nov 15, 2006 | 08:41 AM
slvrcsi's Avatar
Default 98' CX brake problems
My brakes are literally none existant after a min of driving, and then i have to pump them to get any braking back. By none existant i mean my foot goes to the floor board with no resistance.
I was told to replace the Master Cylinder, does anyone else have any suggestions?
Do you need more information?
Old Nov 15, 2006 | 08:51 AM
Mario_D's Avatar
Default Re: 98' CX brake problems (slvrcsi)
Was the brake fluid recently flushed? It sounds like you have a lot of air in your brake lines. You may consider bleeding the brakes.
m-
Old Nov 15, 2006 | 09:00 AM
slvrcsi's Avatar
Default Re: 98' CX brake problems (Mario_D)
just replaced the Right front caliper thinking that was the problem, only because it was saturated in brake fluid. So i bled the brakes after that and still have the same problem!
Old Nov 15, 2006 | 09:03 AM
pdiggitydogg's Avatar
could be air in the lines
could be bad master cylinder
could be leaks in the system
Are you losing fluid or is it at a good level?
If its alright, I say bleed the lines too All of them...in the right order...twice.
Make sure your MC doesnt go dry doing this, or you'll suck more air into the system
Old Nov 15, 2006 | 10:19 AM
BlueIntegraBoy's Avatar
To check for a leaky brake MC, check around the firewall or where the pedals meet the firewall for any moisture.
Old Nov 15, 2006 | 10:22 AM
slvrcsi's Avatar
Default Re: 98' CX brake problems (BlueIntegraBoy)
Alright ill check that out!!
One other question i have is i noticed the gas pedal has about 2-3 inches of movability, is this common in the CX?? i remember my Ex having a whole lot more of movability than this car.
DriveSlowHomie
Jan 31, 2008 03:14 AM
dng
Jul 3, 2005 09:24 PM
The Hooligan
May 5, 2005 03:32 PM
sacredc0w69
Apr 29, 2003 11:05 AM
tilt
Mar 11, 2003 08:52 PM
