Braking problem?
Old Apr 27, 2003 | 06:30 PM
sacredc0w69's Avatar
Default Braking problem?
Hey, i drive a 4th gen 1990 accord
in teh winter every once in a while when i pushed on the brake to stop the brake would just continuie to move in until it reached thefloor
on warm sunny summer daysit happens every time i try to brake
it just moves straight down into the floor, yes it does stop but i have to really push down be4 it hits the floor so i can stop on time or i have to realease and push the brake again...any ideas on whats wrong and what i should do 2 fix it?
Old Apr 29, 2003 | 09:08 AM
JimBlake's Avatar
Default Re: Braking problem? (sacredc0w69)
First, bleed the brakes - it might be air in the lines. If the brake fluid hasn't been changed regularly, maybe the inside of your master cylinder and/or calipers has corroded. Then you have to figure out which & replace it. Does fluid leak anywhere? Does the reservoir stay full?
Old Apr 29, 2003 | 11:05 AM
Audi RS4's Avatar
Lover
check the fluid level, then bleed your brakes, to get any air out of the lines.......
da1lydr1ver
Mar 26, 2012 06:25 PM
bonspeed
Suspension & Brakes
Dec 10, 2009 01:10 AM
UltimX
21
Feb 8, 2006 08:29 PM
H.crx-si
Jul 6, 2003 10:05 AM
RCautoworks
Apr 15, 2003 08:53 PM
