tranny question
Old May 7, 2002 | 11:15 PM
BYT's Avatar
BYT
Default tranny question
hey guys i just picked up a 92si recently. the previous owner had installed an act extreme clutch (i know that's the pressure plate, dunno what disk is in there) and the engagement seems pretty rough. I've gotten used to it after a few days but the shift into second gear hasn't seemed to smooth out. when i shift out of first at 3500 i have to let it drop to around 2000 before it engages even semi-smoothly. is this a sign of bad synchros? the other gears seem fine. any help is appreciated! thanks.
Old May 8, 2002 | 03:58 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: tranny question (BYT)
shifter fork most likely..........
he is my last one...........
part is about $50 from dealer and figure atleast 4-5 hours to R&R tranny and split it open to get at the shifter fork.
But them I'm better than most.
http://home.cinci.rr.com/mistab0ne/tranny.html
Old May 8, 2002 | 06:45 AM
liam821's Avatar
25 Year Member
I would guess the syncros are going out personally....when you break the shift forks you can hardly shift into gear at all. (i lost 3rd gear all together)
Also you dont normally break the 2nd gear shift fork..its normally the 3rd which goes..
heres what mine looked like when i broke my 3rd gear shift fork...
liam
Old May 8, 2002 | 07:17 AM
BYT's Avatar
BYT
Default Re: tranny question (liam821)
ouch...
are there any tell tale signs to know for sure what's wrong? how much it would be to replace the synchros? i'm not too familiar with tranny work...thanks for the info already guys
Old May 8, 2002 | 07:32 AM
94CivicSi's Avatar
Personally dude, I try to find a replacement from a salvage yard or maybe someone who's swapped out their SOHC (assuming you're still running a Z6). You could probably get one for a couple hundred bucks, tops. Labor alone just to remove and diagnose the problem at a tranny shop is going to be more than that.
Old May 8, 2002 | 07:33 AM
TurbodCX's Avatar
does any one make after amket shift forks??? i am also having a real hard time getting my car into third gear at full boost high rpms.... does this sound like the shift fork??
brian
Old May 9, 2002 | 03:41 AM
Mista Bone's Avatar
D Tranny Guru
Liam821......2 things.........
your 1-2 fork IS broken!
Your only the second person I've heard of break the 3-4 fork.
I've only ever seen 2 bad synchros in a D tranny. Last shifter fork wiped 70% of the teeth of the synchro.
Old May 9, 2002 | 03:42 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: tranny question (TurbodCX)
usually hard getting into 3rd is just motor mounts.
If it totally refuses to go, then shifter fork.
No aftermarket forks yet, they would cost $1000 a set right now.
Old May 9, 2002 | 05:49 AM
TurbodCX's Avatar
Default Re: tranny question (Mista Bone)
motor mounts???? i just put the energy sus. inserts into my new motor mounts, and also new shifter bushings?? could the fork be bent??
brian
Old May 10, 2002 | 04:07 AM
Mista Bone's Avatar
D Tranny Guru
you can't bend cast alum. shifter forks, they just wear & break.
hondateg10
Jul 22, 2008 03:54 AM
davidluko
Dec 17, 2006 10:51 AM
spyderman_8_2
Nov 24, 2004 11:27 AM
Thundersquid
Aug 17, 2003 07:34 PM
nY's FiNeSt
13
Jul 1, 2003 11:52 AM
