How to remove ARP head studs off B16 block?
Old Nov 14, 2006 | 01:05 PM
tommy.'s Avatar
Default How to remove ARP head studs off B16 block?
i was wondering how do u do it because i have them in a b16 block and wanna take em out and put in the stock ones
Old Nov 14, 2006 | 01:07 PM
Frozen E's Avatar
H-T White Ops
Uhmm, remove/replace. How hard is that?
Just make sure you take 'em out in the right order.
Old Nov 14, 2006 | 01:08 PM
pdiggitydogg's Avatar
dont know why you would want to do that...
Assuming the head is already off...
you have to use the double-nut/lock-nut approach.
Spin one nut on, put a second on, as a lock-nut, tighten the two against each other a bit, and then turn the bottom nut by itself to remove the stud.
Old Nov 14, 2006 | 01:33 PM
sh!tsWEAK!'s Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">dont know why you would want to do that...
Spin one nut on, put a second on, as a lock-nut, tighten the two against each other a bit, and then turn the bottom nut by itself to remove the stud.</TD></TR></TABLE>
Or you could just use an allen key, since the ARP's have holes at the top of them for just that!
Old Nov 14, 2006 | 01:42 PM
dont know about you, but my allen holes started to strip when I was putting mine into freshly chased holes...allen is too small for what they are imo
GSR_hatch936
May 27, 2008 06:09 PM
B18C_EJ8
Oct 29, 2007 04:33 PM
KMk51188
25
Nov 27, 2006 08:53 AM
LSEGHATCH
Aug 14, 2005 09:02 AM
ScottEK
Dec 11, 2004 01:12 PM
