Quick question about ressistors
i had 450's on my car hooked up with oem ressistor box. but im gonna run n/a over winter... can i run stock injectors with the ressistor box? i would take it out but dont know which wires goes to which injector, its too complicated.
technically, you can run obd0 (88-91) injectors with the resistor box. In reality (flame suit on) you can mix hi and low impedence injectors usually without any problems.
i wanna put obd-1 injectors back on with the ressistor still hooked up. the ressistor is all solder up and i dont want to rewire it cause its gonna be a b*tch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch »</TD></TR><TR><TD CLASS="quote">its for my obd-1 car so i only got obd-1 injectors</TD></TR></TABLE>
That doesn’t matter as long as you are running the resistor box.... I don’t think you will have to modify anything to plug them in either (but I could be wrong not 100% sure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
That doesn’t matter as long as you are running the resistor box.... I don’t think you will have to modify anything to plug them in either (but I could be wrong not 100% sure)</TD></TR></TABLE>
what i mean is that i have only a set of obd-1 injectors, im not gonna spend money to buy some 0bd-0 injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch »</TD></TR><TR><TD CLASS="quote">what i mean is that i have only a set of obd-1 injectors, im not gonna spend money to buy some 0bd-0 injectors</TD></TR></TABLE>
why are you asking the question if you know you're not gonna buy any other injectors?
Just put your stock ones back in... it will run fine.
cor4ey
Nov 4, 2007 05:06 PM
cheap too
$30/shipped and their urs
