95 ex d16z6 code 43 running REALLY rich help!
Old Nov 12, 2006 | 02:39 PM
D16Y8-JDMYO's Avatar
Default 95 ex d16z6 code 43 running REALLY rich help!
oh
Old Nov 12, 2006 | 02:59 PM
nastynutsnash's Avatar
Default Re: 95 ex d16z6 code 43 running REALLY rich help! (D16Y8-JDMYO)
maybe stuck injectors
o2 sensor
im just taking a guess
Old Nov 12, 2006 | 03:46 PM
Default Re: 95 ex d16z6 code 43 running REALLY rich help! (nastynutsnash)
the o2 sensor probably will have to be replaced after running so rich, but the problem is right at startup its already extremely rich, isnt the car usually in open loop/ignores sensors during initial warmup?
that's the only reason i had to eliminate that.
the injectors... is it likely that all of the injectors will become stuck at the same time? ALL the spark plugs are black.
Old Nov 13, 2006 | 04:51 AM
EE_Chris's Avatar
When the engine is started cold, it's in open loop. Open loop runs richer than closed loop because it's ignoring O2 feedback. I doubt all your injectors stuck open at the same time.
Is this just a stock D16Z6?
Old Nov 14, 2006 | 11:24 AM
Default Re: 95 ex d16z6 code 43 running REALLY rich help! (EE_Chris)
yes, its completely stock. not even an intake.
and when i say rich, i mean black smoke out the tailpipe rich.
Old Nov 14, 2006 | 12:47 PM
Bakeoff's Avatar
sounds like you need to recheck you timing belt. Does it have normal power? I'm guessing it's doggy as hell and you're off by a tooth or more.
Old Nov 14, 2006 | 02:37 PM
2to5coupe
Guest
Posts: n/a
Default Re: (Bakeoff)
what kind of fuel map? recent swap? what kind of swap, what year into what year?
Old Nov 14, 2006 | 04:44 PM
Default Re: (2to5coupe)
the engine is completely stock, d16z6 95 civic ex coupe. ecu is stock P28, i've never touched the ecu.
i just rechecked the cam timing today, lined up fine
even before i replaced the timing belt it felt fine when i floored it, didnt feel like it lost any power.
when it's idling it bumps, feels similar to misfire.
when i move the throttle by hand even a little bit, will bog down to 500rpm like its about to die, then recover. this is also true for when i rev it.
seems like its so rich its bogging the engine down.
Old Nov 18, 2006 | 12:23 AM
Default Re: (D16Y8-JDMYO)
nothingggggggggg?
Old Nov 20, 2006 | 04:03 PM
yoooooo
Old Nov 21, 2006 | 04:03 AM
EE_Chris's Avatar
You replaced the timing belt - did you check the ignition timing with a timing light?
Are the distributor coil, wires and plugs OEM or Autozone and the like?
Get rid of the grounding kit and go back to stock gauge wire and stock mounting locations.
Did is just all of a sudden start running rich like that? Or after you did some bit of maintenance?
typeRef
17
Jun 3, 2013 05:35 AM
fabe85
Jun 15, 2007 03:45 AM
ebrakeracin4
12
Apr 12, 2007 11:48 AM
92ehatch
Oct 18, 2006 11:44 AM
j0nptw
28
May 1, 2005 12:05 AM
