VTEC WIRING
Old Nov 12, 2006 | 09:07 AM
JDM94HATCH's Avatar
Default VTEC WIRING
hey whats up..after doing my mini me swap on my EG my friend wired my V-tec for me and when i took it out for a road test the frist time i gas'd it no problem vtec hit but when i really really punched it right after frist gear my CEL went on and its show 21 witch is the VTEC spool solenoid valve correct? so after that my friend tested the solenoid and he said it was fine so do u guys might think this could be i just aa wire touching somewhere or w/e ..and the only reason y i really dont kno what it is because after the CEL comes on V-tec is still poping
Old Nov 12, 2006 | 10:18 AM
D16SohcVtec's Avatar
Default Re: VTEC WIRING (JDM94HATCH)
Check to see if the wire is loose on the solinoid or if the wire to the ecu is loose.
Old Nov 12, 2006 | 03:02 PM
JDM94HATCH's Avatar
Default Re: VTEC WIRING (D16SohcVtec)
i looked at and everything was fine any thinkg else people??
Old Nov 12, 2006 | 03:38 PM
It may look tight, but try and tug on it a bit if its tight then you will know it's tight.
Old Nov 12, 2006 | 04:36 PM
schardbody's Avatar
if you have a code for VTEC, its not working.
Old Nov 12, 2006 | 05:25 PM
JDM94HATCH's Avatar
Default Re: (schardbody)
ok my cel only goes on after 7000 rpm
Old Nov 12, 2006 | 05:58 PM
schardbody's Avatar
Default Re: (JDM94HATCH)
and as soon as it comes on vtec isnt going to engage anymore until you cut it off again.
Old Nov 13, 2006 | 08:13 AM
JDM94HATCH's Avatar
what do u mean by cut it off again
Old Nov 13, 2006 | 09:16 AM
fmrprojects's Avatar
hows your oli pressure? solenoid goes to a4 and pressure switch goes to oil pressure goes to d6
Old Nov 13, 2006 | 09:34 AM
schardbody's Avatar
a vtec code is a soft code, when you cut the car off it resets the soft codes, until the scenerio happens again and the code is set.
once the code is set you wont engage vtec until you cut the car off and it resets the soft codes.
Old Nov 14, 2006 | 07:26 PM
JDM94HATCH's Avatar
so i cant get ride of this code?:?
Old Nov 14, 2006 | 08:14 PM
EH2-R's Avatar
my car also dose this i have a type-r in my 94 hatch and everytime i give it at about 7000 rmp vtec stops and wont work till i turn the car off. has anyone else ever had this problem and if so what might be some things i can try to do to fix this.
Old Nov 15, 2006 | 02:06 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM94HATCH &raquo;</TD></TR><TR><TD CLASS="quote">so i cant get ride of this code?:?</TD></TR></TABLE>
yes, fix the problem and the code wont show up.
wiring loose, incorrect, trash in solenoid, low oil pressure, faulty solenoid.
tarmax
Oct 20, 2010 11:40 AM
Jimster480
17
Jul 27, 2010 12:39 PM
vtieg6
Nov 7, 2009 08:16 PM
soquickls
Jun 28, 2004 05:52 PM
shivic
Jun 3, 2004 11:21 AM
