EG turbo install HELP! DSM injector wiring
Old Nov 12, 2006 | 07:02 AM
Wink1100's Avatar
Default EG turbo install HELP! DSM injector wiring
Using DSM 450 injectors, Got a resistor box. I know that from each injector, i'll be wiring up the each yellow and black wire to each black wire to the resistor box. What do I do with the single red wire?
Also, my friend said it would be easier to use the harness on the drivers shock tower side where all the yellow black striped wires reside. Well, there is 8 of them, which side do I use? i can't find anything on here for reference to wire this injector set up. If you guys got anything, let me know. thanks!
Old Nov 12, 2006 | 07:21 AM
coneheadsracing's Avatar
Default Re: EG turbo install HELP! DSM injector wiring (Wink1100)
How do I install DSM injectors? (thanks 93turbo16)
https://honda-tech.com/zerothread?id=691345
https://honda-tech.com/zerothread?id=195834
http://www.geocities.com/uncgo....html
Resistor Box wiring:
https://honda-tech.com/zerothread?id=441107
https://honda-tech.com/zerothread?id=517274
Arthas
Mar 3, 2010 05:08 PM
GReddy SI
25
May 26, 2004 11:37 AM
SPOOLINTEG
Mar 10, 2004 10:40 AM
importfan2
Mar 14, 2003 12:00 PM
